I have the desktop set at 1600x1024 now and text is very clean.![]()
Why would you use 1600x1024 instead of 1600x1000 (the latter is the fw900 16:10 aspect ratio).
Also, am I the only one who prefers lower res? I'm running 1280x800 @ 120hz and it looks gorgeous. Anything higher and the text is too tiny! (although it still renders cleanly)
Could still use a bit of help on this. Today when I turned the display on, it started that quick thin tearing and popping sound. After about 10 minutes I got one big "snap", the screen blacked out for just a fraction of a second and then came back... apparently fine. No visible tearing now.
BTW, this is on a static screen. No motion or gaming.
Loved your account of getting the monitor.
Yes, 1600 by 1024, is perfect to match aspect ratio. Used that resolution for years. (FW900 is not quite wide enough to actually be a 16:10 monitor. That's only if you letterbox a bit. Never saw a need to do that though...)
Good God this is still going on! Unkle Vito is solid and its garbage like this that fuck it up for everyone else and make it harder for the rest of us to get a FW900 from vito because he moves one more step closer to saying fuck it no shipping anymore![]()
Absolutely. Unkle Vito is a stand up guy. And very nice and helpful. Got my 2nd FW900 from him years ago and it's still going strong at my Dad's.
Unkle Vito,
What were the highest vertical refresh rates at various resolutions (like x480, x720, x800, x960, x1080, x1200, x1440, etc.) that you've seen CRTs run at?
Hey Vito, thanks for all the work you do in keeping the CRT's running around the world! I have a couple questions for you:
1. I obtained a free NEC FP2141SB recently. It has a problem where the screen will just blank and disappear, yet the green LED stays on as if nothing is wrong. Most of the time when I turn it off for a minute it will return, but only for another 1/2 hour to an hour, sometimes less. What do you think is causing this problem?
2. Is it possible to use the NEC tube as a backup tube for my LaCie electron22blueIV? I'm pretty sure they're the same monitor. All the options in the OSD exactly the same, just the font is slightly different.
Im using 9300 color temp and 12% brightness, contrast at 91%.
Hoping my 2003 NEC FE2111 gets me to OLEDs, and I can just bypass TN/IPS/VA panels completely
. Did you use the "Constant Brightness" function after you warmed it up for a half hour or so?
And a very interesting video presentation by sony on this new tech. There's a fascinating graphic that compares OLED, CRT, lcd and plasma.
http://pro.sony.com/bbsc/video/collections-technology_training/video-prenab2011_oled_training/
Picked up an NEC FE2111SB today for $40.
Manufacture date is July 2003.
Works perfectly and I'm very happy with it.
After some time with calibrating it, the picture quality is awesome !!
Great color, sharp text, great geometry, blacks are really black and white is nice and white.
Id put its quality very very close to that of an FW900 or GDM-C520K
I have the same monitor but theres no windows 7 driver which makes things a mess to the point im tempted to move to lcd. If you have the nec drivers installed and have an nvidia card could you do me a favor. If so set your monitor to 1024x768@120hz in windows display then go into the nvidia control panal and let me know what the settings are listed as in the custom resolution.
This was an interesting presentation, curious that he claims that their OLED is 100 times faster than CRT.
