I will be moving into a new house soon with a more extensive network than I presently have. Each room will have a minimum of one home run to the patch panel downstairs and there will be several home runs to the theater, office, master bedroom, etc. My trusty Dell PowerConnect 2716 switch no longer has enough ports and also does not have built-in POE. I would also like to ditch the smaller additional switches (two D-Link DGS-2205’s) I now use in my theater and office.
I am soliciting your recommendations for a home network switch with at least 24 ports, POE, Gb speed on all ports (at the new place all cabling, keystones, connectors and the 24 port patch panel are Cat6) and VLAN (to allow for a separate ‘guest’ networks) as well as any other features you think would be a good idea. FWIW I am not a networking guru but I do have a solid grasp of the basics and have setup my own networks and done all of my own wiring thus far. I will attach a couple of photos below.
I would like to stay below $1000 if possible but I am willing to spend more for a highly recommended switch with an excellent feature set. One switch in particular that seems to have the features I am looking for is the Cisco SGE2000P, available on Amazon for $665 USD.
Thanks in advance for your help and recommendations!
Some of the changes not shown on the network map image below are the added VoIP service, 2 streaming media hubs, an ‘N’ WIFI router (replaced the old WAP54G), another PC, a Netbook, replaced the Foscam IP cameras with Vivotek models and a few other items. My new AV receiver also has an Ethernet port.
