20in ips monitor 89.99 prime at amazon
robothunter
Too bad it doesn't have a uniform bezel. I could see using 6 of these in a multi-monitor setup.
Sycraft
Well the nice thing about 1600 in that size is it works for a PLP setup well with a 30" monitor, which is 1600 vertical.
Citizen86
Would it line up with the 30" though? Same resolution is good, but if one is bigger than the other, it sort of defeats the purpose.
Also, not to thread crap, but I was at Best Buy yesterday and picked up two of these: AOC 21.5" IPS LED
$120 for a 1080p IPS, but what was amazing was ringing it up, and there was an unadvertised buy one get another half off sale. So I walked out with 2 of these for $202 total, tax included.
Probably a big YMMV, it was at a San Diego location, but it is IPS and 1080p. I'm pretty pleased with them, working on them now :)
xp3nd4bl3
Looks like a great entry triple-monitor setup. Thin bezel, lower resolution means less GPU required to power it.
Goodfellah
You need 1600x1200 for 20-30-20 PLP to work, that's how mine was anyway and it was damn near perfect, I moved on to dual 30"s after that though...
LTR
wow dual 30in monitors thats a lot of pixels to look at.
