2080ti 2080 Ownership Club
Discussion in 'nVidia Flavor' started by Comixbooks, Oct 5, 2018.
  1. Solhokuten
    Solhokuten [H]ard|Gawd
    1,167
    Dec 9, 2009
    I noticed the EKWB and RTX logos are not LED lit on yours either. They appear to be illuminated in some of the pics and videos on the web. Any ideas?
  2. Dayaks
    Dayaks [H]ardness Supreme
    6,458
    Feb 22, 2012
    Pretty sure it’s an option. The RBG ones.
  3. Supercharged_Z06
    Supercharged_Z06 2[H]4U
    2,382
    Nov 13, 2006
    Ya, it's an option. Bought my card off of Vega who opted for the none RGB version it seems. Probably would have purchased the same as the pretty lights on a waterblock only add an extra 0.00001 fps last time I checked. :D
  4. Solhokuten
    1,167
    Dec 9, 2009
    I actually have the RGB edition. From your pics it appeared you did as well. Guess I was mistaken.
  5. homernoy
    homernoy Limp Gawd
    440
    Jan 31, 2007
    I have an RTX 2080ti, but my benchmarks are low. I'm getting 7886 in Port Royal. My specs are in the sig below.
  6. Dayaks
    6,458
    Feb 22, 2012
    Did you do any tweaking at all yet? Power limit? Fan profile?
  7. homernoy
    homernoy Limp Gawd
    440
    Jan 31, 2007
    I've been using MSI afterburner, and the highest I can clock the core is 82MHz. I haven't tried to increase the voltage, due to the fact I don't want to harm the card. I've also run the fans at 88% and the highest temp I recorded during any benchmark was 76C.
    I have increased the power limit to 111, but it doesn't seem to do much of anything.
  8. Supercharged_Z06
    2,382
    Nov 13, 2006
    Yup, my card is this one: EK-Vector RTX 2080 Ti - Copper + Plexi which doesn't come RGB equipped. Your card is probably the Nickel + Plexi version which does.
    NestedRAID likes this.
  9. Dayaks
    6,458
    Feb 22, 2012
    OCing a little (2115/+1000 mem) got me to 9k Port Royal. I've never maxed out my memory since that would require installing PrecisionX rather than Afterburner... but I am happy with this.
    https://www.3dmark.com/pr/16703
    What's interesting is in all cases I've seen so far DXR features drop power usage compared to straight up rasterized. I wonder if there will be a case one day where that is not true. Maybe no RT, just DLSS? I've never tried the Final Fantasy benchmark.
  10. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    What is your power target at? 110-120%?
  11. Dayaks
    6,458
    Feb 22, 2012
    I flashed the Galax bios. So with +126% it’s 380W.
    I also shunt modded but it didn’t gain me anything over the Bios flash... yet. So far it seems ray tracing is such a bottleneck it holds back the CUDA cores where power usage drops a little.
  12. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    Yea that's what I was afraid of. I really don't want to void my warranty. Good job on your overclock and score. I think the last time i tested my score it was 8300 ish 2085/800. I can't wait to run that test when my 2nd card + nvlink arrives on tuesday.
    Dayaks likes this.
  13. Supercharged_Z06
    2,382
    Nov 13, 2006
    Armenius, Maddness, Dayaks and 2 others like this.
  14. Montu
    Montu [H]ard DCOTM x4
    7,785
    Apr 25, 2001
  15. Dayaks
    6,458
    Feb 22, 2012
  16. Supercharged_Z06
    2,382
    Nov 13, 2006
    Thanks, Yup, very much watercooled. :D
  17. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    Hey Dayaks.. Can you message me information on how to flash GPU bios? I'm having second thoughts.. I might give that a try. My card is in my signature.
  18. TahoeDust
    TahoeDust Limp Gawd
    485
    Dec 3, 2011
    I am pretty sure you cannot flash the EVGA Black card.
  19. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    Ah good to know. I think it is for the best especially regarding warranty.
  20. Kor
    Kor 2[H]4U
    2,180
    Mar 31, 2010
    There is a custom release of NVflash that's floating around which will allow your to cross flash between vendors on using the FE PCB (nvflash_5.527.0_modified).
  21. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    I will research this and see If i can come up with something. I figure there's someone that has done it before.
  22. Kor
    Kor 2[H]4U
    2,180
    Mar 31, 2010
    I have, I'm running an FE with the EVGA XC Ultra vBios.
    Armenius, Maddness and NestedRAID like this.
  23. Kor
    Kor 2[H]4U
    2,180
    Mar 31, 2010
    I should point out however that I'm not sure if the Black is running the "A" silicon which would determine how stable it would be using the XC/XC Ultra vBios.
  24. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    Honestly, I don't expect it to at $999.99 per card it was a great value when compared to other 2080Ti prices. I may not get the most insane clocks but my performance has been more than enough to push games using my Acer X34 predator 3440x1440p with max settings within 100-120 fps. Thanks for going out of your way to let me know the options and what to look out for. I really appreciate it.
  25. TahoeDust
    TahoeDust Limp Gawd
    485
    Dec 3, 2011
    It is not using the "A" binned chip and will not work with a bios made for the "A" binned chips. It cannot be flashed with a higher power limit bios because they are all for "A" chips.
  26. Dayaks
    6,458
    Feb 22, 2012
    I sent you the place to go. The 380W galax bios worked great on my ref pcb asus dual.
  27. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    Thanks for doing the leg work on the research. I will keep this in mind down the road when I pick up the next pair of Ti's. Much appreciated.
    Thanks a ton for the information. Unfortunately it looks like it wont work on my cards, but I will use the information as a reference. Thank you kindly.
  28. Dayaks
    6,458
    Feb 22, 2012
    At worst you might be missing out on 5% perf. When you waterblock the cards don’t increase voltage, just max the power limit and increase freq first.
    Also when I ran sli with 1080s if they throttled at all my frametimes went to hell. Watch out for that.
  29. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    Thanks for the advice. I will remember it when i get my ek parts in february. I am also looking forward to the cpu cooling it will provide. the 8700K is a hot cpu and on air im getting 70-85C at 5ghz. Something that I know will be much lower with a velocity ekwb.
    EDIT:
    You know what Dayaks I completely forgot about the damn evga step up program. I have 71 days left on this card and ill have a full 90 on the card that comes in tomorrow. Im going to mull it over but I may just step both of them up to XCs so that I can get into the much higher power bands.
  30. Slade
    Slade 2[H]4U
    2,521
    Jun 9, 2004
    Thanks to my RMA, EVGA has sent me both a red and a black trim kit bringing my total to red, white or black for accents. I feared shutting off my system to replace them but settled on black. I may go red later if I turn on the LED of my mobo as it has a red glow theme to it.
  31. Supercharged_Z06
    2,382
    Nov 13, 2006
    Careful, the red trim may slow performance down by a good 4-5% as the card may get slightly confused thinking it's an AMD product. :p
    1st world problems... How your $1350 card looks and which trim accent it should sport for max performance. :D
  32. Armenius
    Armenius [H]ardForum Junkie
    15,844
    Jan 28, 2014
    Menthol is using a much older driver version than you are (411.63 vs. 417.35). Menthol's score was also done on Windows 10 1803 while yours is with 1809. Yes, 3DMark scores can vary wildly between driver and OS versions.
  33. mikeo
    mikeo Limp Gawd
    275
    May 17, 2006
    Did some video editing over the weekend, nvenc render with a 2080 ti is pretty nice.
    Edit: takes 1 min 28 sec to render a 3 min 20 second file in mp4 hevc using the 1080p nvenc preset in vegas video. HEVC is stupidly slow rendering via CPU only so quite happy with that. This card isn't just for gaming.
  34. spintroniX
    spintroniX Gawd
    957
    Apr 7, 2009
    No formal benchmarks to report, but for my deep learning project the 2080Ti is about 25% faster in FP32 work.
    I did some gaming last night, PUBG for about 2 and a half hours, 4K Medium AA, High Shadows, Ultra everything else and it's incredibly smooth.
    The experience was on par with my 1080Ti at 4K with low / medium settings.
    I don't have the NVLink bridge yet, so no SLI results to report, but single card is insanely fast.
    NestedRAID and mikeo like this.
  35. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    I didn't even think about that. Makes sense but I am also sure there's a few things i can do to increase my score.
    I have my NVLink bridge coming tomorrow. Pretty excited.
    spintroniX likes this.
  36. Slade
    Slade 2[H]4U
    2,521
    Jun 9, 2004
    If you can take advantage of scaling your data to 16bit or even 8-bit range, you will see a big performance increase with the 2080ti for both inference and training aspects of deep learning.
  37. spintroniX
    spintroniX Gawd
    957
    Apr 7, 2009
    Yup, that's the idea. when trying to use fp16 backend I keep running into NaN loss (immediate) with a fully convolutional model in Keras. Debugging that to fully realize the gains that Turing has to offer.
  38. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    Armenius likes this.
  39. Armenius
    15,844
    Jan 28, 2014
  40. NestedRAID
    NestedRAID n00b
    26
    Jan 10, 2019
    If they had this earlier I probably would have got it instead of the two hydro copper water blocks but now I am fully committed to a custom liquid loop! Only have fans, fittings, and tubing left for the end of the month paycheck hype!
    Supercharged_Z06 and Armenius like this.
