cybereality
- Mar 22, 2008
Maybe it connected to an open wifi network in your area...
Sketchy AF, tho.
Sketchy AF, tho.
How does that different from Auto Motion Plus?
Some people on here used to like it, but I found it added a shit ton of input lag making games almost unplayable.
I'm assuming that's a typo, but it's pretty great.I couldn't tell any difference between Game Motion Plus and Feesync as far as input lag was concerned.
AMD FreeSync versus Nvidia FeeSync![]()
oddly switching from blu ray to game mode uses the same settings. Anyone have this issue?any ideas on how I can make my input lag even lower in game mode. Playing apex legends and its still high
Game mode is tricky on my set. By default my PC doesn't like it. It keeps trying to swap back to the "PC" input....which luckily also has input lag reduction.
Instead I use the "Game Console" input mode for HDR content. HDR content is laggier to begin with and it requires separate calibration settings, so it works well for me.
Plus, whatever causes my TV to keep reverting to the "PC" input seems to disable itself whenever HDR content it shown.
My first gut instinct is to ask, have you tried with a different high bandwidth HDMI cable?
At least when these things were new, lots of random issues like this were cable related, as full HDMI 2.0 bandwidth utilization just would not work on many cables, especially on cables longer than 10ft.
My 2015 Samsung is dying. For some reason I have to keep selecting the input to get it to work, occasionally loses input altogether.
Unfortunately not that one. It's the low-end 4k 48" one. No biggie, I planned on buying a better 4k display anyways. While this one is decent I'd like to get a display that supports adaptive sync.Which model is it?
If it's one of the ones that has a One Connect box, you might be able to solve this issue by just replacing the box?
Not recently. I'll try it again.Did you try a factory reset? That helped me with a UI issue I was having.
Funny thing that you write this! I have a JS9000 and when I move my tv for gaming and move the Sonic Carrier away the inputs also seem to get scrambled. I have to turn the TV on and off for the screen to come back on!My 2015 Samsung is dying. For some reason I have to keep selecting the input to get it to work, occasionally loses input altogether.
I'll try this! I think I even got an extra when my first one died!Which model is it?
I know jack about tv's, and this has probably already been talked about in this thread. Taking a look today I'm seeing 4k 120 hz and 240 hz tv's available right now. I'm thinking on whether it might be worth trying one of the smaller sizes as a monitor. 4k 60 hz for desktop. 1080 120 hz for gaming.
Hello!
So I was wondering if someone could help with their favorite FPS shooter settings for the TV. I read a few people use Dynamic with Motion plus set to standard.
What are your other settings for this and what source do you have it set to? I am trying to have a more fluid FPS experience in games like APEX and right now just have it set to Game mode.
Love to hear the input!
The end result is definitely smoother, but you've just added a shit ton of lag.
I am doing the same thing! I have a Creative Sonic Carrier and it acts as my receiver! What color mode are you using? I use PC Mode for PC usage and it makes work a lot easier.I think it relates to me using an A/V receiver for audio. While initially an annoyance, it has turned out to be something I really like. PC mode still has lag reduction (just like game mode), and it gives me a 1-button toggle for other content.
All of my consoles and my cable box are all calibrated for the color scheme I setup for the PC input mode. Whenever anything with HDR kicks in (like Netflix or a game), I just hit the input button and toggle it over to Game Console mode, which has my HDR color settings.
I wanted to really have a go at this but when I set dynamnic contrast the colors are more blue / slightly colder / feel offAlmost 4 years later, I'm still using game mode. I know some people really like Auto Motion Plus (AMP) but you have to have a pretty low sensitivity to input lag for that to work for you.
The problem with interpolation is that the screen has to wait for the next frame before it can interpolate between the two. So right there you have at least one frame of input lag.
Then there is the processing time to interpolate the frame. Add that to your input lag.
Try it. If you like it, great! It wasn't for me though.
Exactly this. It was interesting to play with and looked nice, but whew...very noticeably increased lag. I ended up going back to Game Mode for the remainder of my time with the JS9000.
Then I use Blu ray mode for movies
Then I use Game mode for games
It seems Blu Ray / Game mode does not seem to make any difference in settings and it only changes when I set it to Game in General options
Would love to hear what youg use for gaming settings wise. I feel I may have played with a few too many settings . I found sharpness in game mode really helps.
The under-49" HDTV market is sorely neglected. There are two new 43"ers for 2019, Samsung Q60R and Sony X800G, but neither is much improved over their predecessors.So, SUPER PISSED - I was hooking up an HDMI cable today and the tip of the cable fell onto my screen, BARELY touching it yet causing a dead pixel that my eyes can not unsee now.
What's the best 42-43" for 2019 in terms of picture/response? Anything new out - I haven't done any research in quite some time.
I'm tired of it myself. The 2015 48" Samsung I use leaves a lot to be desired.Yep. Smaller TV's tend to be less featured than larger ones as well.
I guess people who want better TV's usually want them in bigger sizes. Those of us who use them as monitors are probably not a very large market.
At least the Asus ROG 43" 4k 120hz FreeSync2 screen and the Acer Predator 43" 4k 144hz AdaptiveSync screen should both hit this year.
Once proper monitors in this size hit, I see little reason to keep trying to use a TV as a monitor.
We are in 2019 now, is there a better one?Good stuff. I'm thinking of going this route. Any reason to pay more to get the higher cost models for monitor use?
