2008 R2 server in datacenter has different timezones for the same logon
Discussion in 'Networking & Security' started by aronesz, Apr 26, 2012.
  1. aronesz
    aronesz Limp Gawd
    389
    Oct 17, 2011
    Greetings,
    We have a 2008 R2 Citrix server that shows -6 GMT (correct) when we RDP into the server on the same administrator account. We have been having problems with the server rebooting at the wrong time. When the datacenter techs login into the same administrator account, for them it shows that the timezone is set to -5 GMT (incorrect).
    Same user account, same server, different timezones. Could someone explain this? :D
  2. k1pp3r
    k1pp3r [H]ardness Supreme
    7,781
    Jun 16, 2004
    Is this a VDI deployment? if so a VDI container could have a different time zone i believe
  3. Protoform-X
    Protoform-X [H]ard|Gawd
    1,203
    Jan 30, 2002
  4. 4saken
    4saken [H]ardForum Junkie
    10,775
    Sep 14, 2004
    Guessing this is the case. You could go in and not allow timezone from the client, but that causes other issues since you probably want timezone from the client. At least in our infrastructure we do. But, we also dont have to worry about administrator level folks logging in from different locations. If its not required, simple as turning that feature off in the gpo.
  5. Thor
    Thor 2[H]4U
    3,889
    Jul 23, 2001
    So, not the right answer, but the simple solution. Why not set it to reboot + 1 hour...
    You want the server to reset at 6, it thinks it's 5, set it to 7... Reboots at 6.
  6. Skud
    Skud Gawd
    588
    Sep 4, 2002
    I'm guessing that it's probably timezone redirection (as said above). Also, does the timezone reset back to -6 once the -5 clients log out? If so, that might be a solution if you can't disable timezone redirection. Just make sure the admin clients log out instead of disconnecting the session.
    Riley
