The Apple is $999 while the Dell is $749. What is the difference between the two and which is the better value? I would be using the displays mostly for gaming and watching D.V.D's. I soooo can't afford either of them but I'm getting one on credit
ou w
I would also go with some kind of an extended warrentee program. Which would you prefer if you were using the specks in my sig. and worked VERY hard for your money. Thanks.
