Hi guys
I'm looking for some suggestions on a project I have set, basically I want to formulate my solution around the following:
2 x VMware ESXi 5.1 Hypervisors (currently I am battling between Dell and SuperMicro)
2 x SANs (leaning towards fiber, though I would love to go with Infiniband)
2 x FC switches
2 x Gigait switches (most likely C3750G's stacked)
The complexity here is two SAN's, the interconnectivity is straight forward enough with both hypervisors "seeing" all datastores; but I need to be able to failover automatically VM's between SAN's. Clearly there will be replication between SAN's handled by the SAN itself, but I need VMware to be able to bring failed over VM's online in the event that either one of the SANs is out of service.
I know I can use FT, HA cold boot, vsphere replication etc if I lose a Hypervisor, but what about where the VM exists entirely on datastore1 (SAN1) with SAN replication to SAN2 and SAN1 one is lost?
Site Recovery Manager looks a good fit for this but in all honesty I have never used it so I'm looking at you guys for some feedback based on field use, plus any other suggestions you might have.
FYI both SAN's are not geographically dispersed they are in the same DC location which helps.
On the subject of SuperMicro I have never used them in production / critical environments before, how do they compare? (I am not in the USA, so they are not as well known here but we have suppliers), any feedback (they are actually cheaper than Dell servers here) would be most welcome from production / critical environments.
SAN wise I am torn towards NetApp but previously I went with EMC (an ISCSI solution) - I have used both.
Now I am going to go and see if I can download a trial version of Site Recovery Manager
Thanks
2 x FC switches
Thanks
