Zarathustra[H]
- Oct 29, 2000
Hey all,
I have been considering adding some radiator capacity to my build for some time, but in doing so, I am not convinced my single D5 will be sufficient to keep up with the desired flow rate of > 1 GPM.
I started considering various solutions, like dual pump tops, and putting pumps in various locations of the loop, but none of them really appealed to me.
Then I had an idea. What if I split it into two loops?
No, I'm not talking the way people normally do it, with a separate loop per component. That is inefficient and I don't want to do it.
I was thinking as follows. Two pumps in separate loops, both pulling from the bottom of a single large reservoir, and returning at the top of that reservoir.
Loop 1:
Reservoir -> GPU -> CPU -> Reservoir
Loop 2:
Reservoir -> All the radiators -> Radiators
The idea is the hot return from the block loop mixes with the cold return from the radiators in the reservoir.
The potential benefit is, because there are only two blocks in one of the loops, that flow rate can go pretty damned high minimizing the DeltaT between the coolant and the die.Meanwhile, if there is a lot of resistance in the radiator loop, and the flow slows down, it's not as much of a big deal
I would set pump speed for the block loop based on the max of the coolant temp leaving each block, and the pump speed and fan speed for the radiator loop based on the temperature of the coolant leaving the reservoir.
Functional idea, or stupidity?
I'd appreciate your input.
Loop 1:
Loop 2:
