Sep 12, 2018 #1 E evilpaul Limp Gawd Joined Dec 31, 2016 Messages 183 I've got a 2 slot GPU, PCIe SSD, and another PCIe SSD currently installed on my board. Will I need to remove/replace the closest PCIe SSD card if I get a 2.75 slot high end card? I'm worried the fans on the GPU might be choked off.
Sep 12, 2018 #2 H H2R2P2 Limp Gawd Joined Jun 18, 2006 Messages 412 Need to know what motherboard you have first.
Sep 12, 2018 #4 Armenius Extremely [H] Joined Jan 28, 2014 Messages 42,122 What slot is the closest SSD plugged into? If it's the second x16 slot you'll be fine.
