SiliconSwitch
- Feb 6, 2006
I apologize if this question has already been asked a million times. I just set up a Dlink DIR-825 in our new house and I'm trying to decide which frequency to use for our laptops. I used a wifi strength meter to survey the house and it seems that the 5ghz band gets about 10% less signal throughout the house. I read that the 5ghz isn't as good at going through objects/walls as the 2.4ghz is due to the wavelength. I also read about interference on the 2,4ghz band due to cordless phones, microwaves etc...
Long story short, am I better using the 2.4ghz range for our laptops since it has the better range? I could use the 5ghz if I needed it for saying streaming hd movies or something like that.
Thanks
Thanks
