2.4ghz and 5ghz and the same time for a low price.
Discussion in 'Networking & Security' started by butterfliesrpretty, May 6, 2018.
  1. butterfliesrpretty
    butterfliesrpretty 2[H]4U
    2,487
    Mar 15, 2002
    Just trying to find a router that does both frequencies at the same time that I can find used cheap. Don't need super fancy just something that gets the job done. Appreciate any help with this.
  2. IdiotInCharge
    IdiotInCharge Not the Idiot YOU are Looking for
    7,943
    Jun 13, 2003
    That's nearly all of them... Go buy the cheapest TP-Link wireless router you can find at Wal-Mart etc.
  3. butterfliesrpretty
    2,487
    Mar 15, 2002
    I just bought one that does one or the other not both at the same time, I would just search for dual band, but I don't know how to specifically seek out the specific feature of being able to use both at the same time.
  4. Brian_B
    Brian_B [H]ard|Gawd
    1,925
    Mar 23, 2012
    I don't know that I've run across that would have both frequencies, but only do one or the other at any given time. That certainly isn't common in my experience.
    What router did you buy that doesn't do what your wanting?
  5. butterfliesrpretty
    2,487
    Mar 15, 2002
  6. Brian_B
    Brian_B [H]ard|Gawd
    1,925
    Mar 23, 2012
    Well, the router you bought is almost 10 years old. The latest firmware is dated 2010.
  7. BlueLineSwinger
    BlueLineSwinger Gawd
    549
    Dec 1, 2011
    I was skeptical, but holy hell, according to the manual (page 29) it really can only do 2.4 OR 5 GHz, not both simultaneously. Odd, even considering the time that it came out.
    I can't give a first-hand recommendation (sorry), but a lot of people seem to like the Asus routers. Just make sure whatever you get is 802.11ac, dual-band, and should have gigabit ethernet ports all-around. Don't worry about superfluous stuff like USB ports for file/printer sharing, as that stuff is usually an afterthought and rarely works well.
  8. butterfliesrpretty
    2,487
    Mar 15, 2002
    Well I'll just get one then that I hope can do both. If I get another one that does one or the other but not both, I'm coming to back this thread and raising hell lol.
    Brian_B likes this.
  9. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,590
    Dec 23, 2001
    Alot of the early N only 5GHZ routers could only do 2.4GHZ or 5GHZ. Now another thing to note alot consumer based routers can not have both 2.4 and 5GHZ on the same SSID network... So idk if thats what you want. 1 SSID that can run both 5GHZ and 2.4GHZ?
  10. butterfliesrpretty
    2,487
    Mar 15, 2002
    Nah just want something where my roommate can connect her ds and older laptop with 2.4, and I can use the higher 5ghz for pcgaming, as 2.4 gets a lot of interference here.
  11. Vengance_01
    5,590
    Dec 23, 2001
    Then any basic router that has AC should do this without any issues.
  12. mwarps
    mwarps [H]ardness Supreme
    7,057
    Oct 6, 2002
    TP-Link Archer C5 on Ebay. $30 used. Go.
    butterfliesrpretty likes this.
  13. jardows
    jardows [H]ard|Gawd
    1,329
    Jun 10, 2015
    No, not any cheap router. Any 802.11ac router will do both, but many 802.11n will not do concurrent 2.4 and 5.0. Due to price, availability, and "newness" I'd just go with an 802.11ac router. Will probably find one cheaper than you would an 802.11n that does both.
  14. IdiotInCharge
    7,943
    Jun 13, 2003
    Honestly didn't think that you could get an 'N' router, so definitely make sure to grab a TP-Link AC version!
  15. rtangwai
    rtangwai [H]ard|Gawd
    1,344
    Jul 26, 2007
    Definitely don't get the Linksys WAP610N.
  16. butterfliesrpretty
    2,487
    Mar 15, 2002
    Got the tplink on the way thanks for the help.
    IdiotInCharge likes this.
