Alright, I'm just about to pull the trigger on this setup. Any flaws or critiques are very much recommended.
I'm thinking of replacing my current rig. [see sig.] But price is an issue
I live in Canada so my main source for components will be
www.ncix.com or www.anitec.ca
Questions are as follows:
-I've never really thought about SLI since it tends to be more pain than it's worth, but it is obviously becoming more popular. I game on a 22'' Samsung but would like to migrate to using my 42'' Westinghouse HDTV. At 1920x1080 does SLI make any difference.
EDIT: [So far the consensus is No]
-I don't know very much about cooling, and I think water is out, so what would I need to invest in to OC that QX6850 with its unlocked multiplier and all? I would like to use my Scythe Ninja REV.B on it if possible, and I have some Artic Cooling MX-2 paste handy.
EDIT: Yate Loon fans or something similar for the Antec P182
-It seems like a waste to gut a perfectly good computer, so I will probably invest in an HD like the WD640AAKS or something similar, and then need to buy:
Case: Antec P182 ATX [$150]
http://www.ncix.com/products/index.php?sku=24122&vpn=P182&manufacture=ANTEC
CPU: QX6850 [$250 - From Intel Retail Program]
PSU: Antec TruePower 2.0 550W [From Old System]
GPU: eVga 8800GT [Stock] [From Old System]
I'll probably buy an Accelero S1 when I find one cheap
Mobo: [$199 - Even if I don't use SLi, I think this Mobo is quite good, but perhaps I should choose another one from the above list and save $$$]
eVGA 750i ftw I believe supports full 2x [16x] PCI-E [$199]
http://www.ncix.com/products/index.php?sku=29440&vpn=123-YW-E175-A1&manufacture=eVGA
Ram: [$99 - These are at a great price. And following tiraides advice DDR 1000 should allow me to realize the full potential of the QX6850]
G.SKILL F2-8000CL5D-4GBPQ PC2-8000 4GB [$99]
http://www.ncix.com/products/index.php?sku=26456
OS...
I have a version of Vista Ultimate 64bit from a Previous Intel purchase, but I've heard it still has compatibilty issues with games etc. Otherwise XP Pro is always there but cannot make use of 4Gb Ram.
HD...
WD6400AAKS [$90]
http://www.infonec.com/site/main.php?module=detail&id=353679
OS...
HD...
WD6400AAKS [$90]
