1920x1200 small monitor?
SeanTek
I'm looking for a 1920x1200 display (16:10, not 16:9!) that is less than 24" diagonal.
Unfortunately, a recent NewEgg search came up with nothing. The smallest 1920x1200 montors are 24" diagonal. In fact, 24" is practically the only size they come in; there are only one 26" and one 27.5" on the market (on NewEgg).
Does anybody know of any display, past or present, that is 1920x1200 and is less than 24" diagonal?
Apple makes 23 inch monitor with 1920x1200 resolution. That is only one i could think of that fits your requirement.
Lenovo L220x, a 22" 1920x1200 with a VA panel, released in 2008. Good luck finding one now. There were two competing 22" 1920x1200 monitors in the same year, but I cannot remember anything about them except that they were quite inferior to the Lenovo.
I think the lenovo 22inch is a good lcd monitor and it matches your requirements.
HP 2335 or HP L2335 (same monitor). It's 23", IPS, cheap, and old.
There's always using a laptop screen and getting the parts to run it and make a case. You can get them in 17".
