16GB Optane as Pagefile in AMD rig.
Discussion in 'SSDs & Data Storage' started by daglesj, May 1, 2018.
  1. daglesj
    daglesj [H]ardness Supreme
    4,924
    May 7, 2005
    Okay been wanting to try an Optane as a Pagefile SSD for a while. Managed to pick up a 16GB on Amazon for £18 this week.
    It's for my other half's rig and I had installed a 32GB Transcend M.2 SATA SSD in there.
    So how do they compare?
    Here is the 32GB Transcend -
    And the 16GB Optane -
    A reasonable improvement! I didn't bother to test it in my X99 rig but I guess it might perform 5-10% faster there.
    Neapolitan6th and ZeqOBpf6 like this.
  2. wra18th
    wra18th [H]ardness Supreme
    7,738
    Nov 11, 2009
    Very nice. Now I want to do the same.
  3. Keljian
    Keljian Limp Gawd
    290
    Nov 7, 2006
    If you need the extra ram it’s handy, but I think it functions best as an L2 cache (see primocache for example)
    The 32gb version is faster again.
  4. daglesj
    4,924
    May 7, 2005
    Yeah but the 32GB version is still £52 at which point it's still too much.
    Plus we don't have any rust spinners in this machine.
  5. Denpepe
    Denpepe Gawd
    844
    Oct 26, 2015
    Think you need kably lake and newer to use it so might not work on x99.
  6. daglesj
    4,924
    May 7, 2005
    Not if you want it to work as a normal SSD. Which is kind of the point of this thread. It will work on X99 just fine. Just not as a HDD Cache drive.
  7. cageymaru
    cageymaru [H]ard|News
    18,637
    Apr 10, 2003
  8. Keljian
    Keljian Limp Gawd
    290
    Nov 7, 2006
    Even so, for random reads it’s very quick, so as read cache for a sata ssd or even an nvme, it can be worthwhile for most desktop workflows
  9. daglesj
    4,924
    May 7, 2005
    cageymaru likes this.
  10. daglesj
    4,924
    May 7, 2005
  11. Keljian
    Keljian Limp Gawd
    290
    Nov 7, 2006
    I guess I'm saying it costs that plus software cost
  12. daglesj
    4,924
    May 7, 2005
    I've lost you there. Where can I get a 800P/900P for £18?
  13. Keljian
    Keljian Limp Gawd
    290
    Nov 7, 2006
    you have a 16 gig 800p? I'm a bit lost also.
    I'm saying you have a 16 gig 800p, if you add primocache to it/the system and allocate that as L2, you'll benefit more than just using a page file on the optane unless you're exceeding your main memory capacity.
  14. daglesj
    4,924
    May 7, 2005
    Ahhh no.
    I have a 16GB ORIGINAL Optane Cache drive, not an 800P.
    A 58GB 800P is about £150 here in the UK.
  15. Keljian
    Keljian Limp Gawd
    290
    Nov 7, 2006
    the original is an 800p
  16. daglesj
    4,924
    May 7, 2005
  17. Keljian
    Keljian Limp Gawd
    290
    Nov 7, 2006
    Not really as all of my tests are with the 32gb original version. I just didn't realise the 800p name only just came in
  18. Keljian
    Keljian Limp Gawd
    290
    Nov 7, 2006
    Size really isn't a huge consideration - 16 gig of cache is a lot.
  19. Brahmzy
    Brahmzy [H]ardness Supreme
    4,959
    Sep 9, 2004
    I guess I don’t see the point. Does this workload page frequently? Ideally, if you’ve built the system correctly, you DONT page, period. Save for maybe certain Enterprise workloads.
  20. daglesj
    4,924
    May 7, 2005
    That's not how Windows 10 works anymore. You used to be able to dump a Pagefile with Windows Vista/7 etc. if you had plenty of RAM. But 10 will kick up if you don't have one or one of a decent size even if you have 16GB+. Certain applications and software trip the Commit Size even if you are just using 8GB of your 16GB of RAM. Windows 10 makes far more use of compression and caching. I think it may well be due to them bringing out those horrible 2GB RAM/32GB SSD machines a couple of years ago. They had to make Windows more 'flexible' with low resource machines.
  21. kdh
    kdh Gawd
    681
    Mar 16, 2005
    Looks great, but are you actually swapping that much where that kind of an upgrade made a difference? If using it as a caching drive, what your cache hit ratios? If you are reading data that much, then those speeds will help, but if you are constantly refreshing your cache tables, the write speeds are important. The write speeds between optane and non optane were a small jump faster, but not much.
  22. daglesj
    4,924
    May 7, 2005
    It was £18 and we had a spare slot. ;)
    Sometimes you do stuff just because...
    At the end of the day the burst rate and latency is also much much better. It all helps.
  23. Brahmzy
    4,959
    Sep 9, 2004
    Hmm. I’ve looked to see if any of my W10 boxes page and they generally don’t, at all. But I could be missing some times when they might be.
    I usually always set a small, fixed 2GB or 4GB PF. With plenty of 900p Optane capacity to spare, I guess I could up that size to 8GB or so..
  24. daglesj
    4,924
    May 7, 2005
    I think its the old adage YMMV. I was finding with a 256/256MB Pagefile (well I wanted software to use that 16GB of DDR4 and have used a 256MB page for years) that when running say Fallout 4/Firefox and a couple of other things Fallout would crash out with low memory warnings even though I was running only half of my 16GB. Checking Event Viewer it was Commit Charge that was causing the issue. There is actual RAM that the software uses then another huge chunk Windows 10 puts 'on hold' for it seemingly through the Pagefile but kind of hidden.
    Setting the Pagefile to System Managed cured it. Sure I could have gone to a 2GB/2GB Page but I couldn't be bothered by then.
  25. Brahmzy
    4,959
    Sep 9, 2004
    Interesting. Must experiment...
  26. Luke M
    Luke M Limp Gawd
    323
    Apr 20, 2016
    It's a cool toy if nothing else.
    Regarding page files, Windows has always practiced strict accounting - you can't overcommit like on linux. Just because you need a page file, it doesn't mean you are actually paging.
  27. Verge
    Verge [H]ardness Supreme
    5,981
    May 27, 2001
    I'm confused... isn't the idea to basically never use the pagefile?
  28. kdh
    kdh Gawd
    681
    Mar 16, 2005
    Totally makes sense.
  29. daglesj
    4,924
    May 7, 2005
    Yep, but Windows 10 runs it all quite differently in the background. Basically the best option is to leave it at default System Managed settings rather than try to out think it.
  30. Brahmzy
    4,959
    Sep 9, 2004
    Do you have any links with data on this issue?
  31. daglesj
    4,924
    May 7, 2005
    You can Google as well as I can...:cool:
  32. Verge
    5,981
    May 27, 2001
    Right, but running an optane page file should give you nothing at all, unless you run out of physical memory.
  33. Brahmzy
    4,959
    Sep 9, 2004
    Well, that's the problem, smartass. This has been a long debate over 2 decades. With not a lot of definitive proof either way. If you've found some magical W10-specifc data that you're preaching, do share, or else you're just blending into the 2-decade old debate. :)
  34. Mega6
    Mega6 [H]ard|Gawd
    1,370
    Aug 13, 2017
    who needs a pagefile? You should be buying enough RAM to prevent pagefile usage and growth.
