1366 x58 Xeon Enthusiast overclocks club
Discussion in 'Intel Processors' started by primetime, May 30, 2014.
  1. primetime
    primetime [H]ardness Supreme
    5,043
    Aug 17, 2005
    That and all the info thus far is that it effects data centers the most and barely anything for desktop usage
  2. Jacob Xeon
    Jacob Xeon n00bie
    3
    Jan 22, 2018
    Help guys.. I just put a x5675 in my x58 evga classified mobo and it’s showing ff and not showing any video out. I have re seated the cpu and tried everything...
  3. kirbyrj
    kirbyrj Why oh why didn't I take the BLUE pill?
    22,292
    Feb 1, 2005
    Does the bios support that chip? Didn't evga have a 2nd revision to their x58 boards because the first Rev didn't support 32nm?
  4. Jacob Xeon
    Jacob Xeon n00bie
    3
    Jan 22, 2018
    I have the 760-a1 does that not work with zeon?
  5. primetime
    5,043
    Aug 17, 2005
    Depends on the revision....seems like EVGA was modding people's boards that was sold with older version.
  6. Jacob Xeon
    Jacob Xeon n00bie
    3
    Jan 22, 2018
    I have a 760 a1 rev 1.0 :( I can’t find any of the mod tutorials because the kingpin site removed them. Anyone have the steps?
  7. Gasaraki_
    Gasaraki_ Gawd
    531
    Oct 27, 2016
    I have been having this issue recently and I fixed it by taking out all the memory and putting them back in AND if this doesn't work try it again but switch the location of just a few sticks. I was able to get all my memory to show up in BIOS again.
  8. Bill1024
    Bill1024 Gawd
    988
    Apr 26, 2013
    Feeling kind of sad, I sold my last x58 motherboard. Asus P6T Deluxe V2 w/E5645 and my EVGA Classified3 with a w3580 yesterday.
    I do have a couple Supermicro dual socket 1366 boards but they are not the same. I need the AVX and other modern instructions.
    So now I have, x79 and z97 and Z370. The i5-8600K hexcore no HT can do primegrid AVX work at 4.6ghz @ 1.260v <70c in 1/6th the time , and 4.7ghz,, non AVX 60c
    I am sure there is more in it taking my time going up.
  9. CyrIng
    CyrIng n00bie
    29
    Apr 15, 2009
    With my venerable X58 setup I have programmed a processor monitoring software which shows Turbo Cores frequency , IPC, Pkg & C-States, Temps, SNB Voltages.... in RT. For example cpuid capabilities, Uncore, QPI, DDR cas & geometry...
    [​IMG]
    CoreFreq is open source into the GitHub http://github.com/cyring/CoreFreq
    A ready to play Live CD can be downloaded from Wiki http://github.com/cyring/CoreFreq/wiki/Live-CD
    I will appreciate any screenshot results of other X58 platforms to help my development progress
    CyrIng
  10. primetime
    5,043
    Aug 17, 2005
    Anyone here had any issues with windows 10 and updates? I ran into issues with using the insider builds would always fail...So i figured lets just do the offical builds...And dang if windows update still has issues, but im sure its the one that was supposed to fix the spectre/meltdown stuff....Now i know why i havent wasted doing clean installs in years since it apparently doesn't really help lol
  11. FlawleZ
    FlawleZ Limp Gawd
    392
    Oct 20, 2010
    Very cool. I'm looking to get my Sabertooth X58 and X5675 setup up and going again this weekend. Will definitely give this a try.
  12. CyrIng
    CyrIng n00bie
    29
    Apr 15, 2009
    Great ! Can't wait too see your results.
    Btw, in GitHub or in Live CD, the corefreq_online_update command will fetch the last stressing functions. Go to the Tools sub menu.
    Enjoy
  13. kirbyrj
    22,292
    Feb 1, 2005
    I just started having issues with the latest Windows Defender. It just won't install. Everything else seems to work ok though.
  14. primetime
    5,043
    Aug 17, 2005
    thanks.....shit i guess it sorted itself out at some point on my end.....shows fully updated now. InSpectre shows my setup as meltdown protected but spectre is still vulnerable. Just a random check with cinebench doesn't show any performance loss, so that parts good. Are we all still waiting for spectre fixes?
  15. diceman2037
    diceman2037 n00bie
    32
    Dec 20, 2011
    just disable meltdown protection, our cpu's can't do it well, and its not even a real concern for end users.
    Big_Rig_Stig likes this.
  16. Big_Rig_Stig
    Big_Rig_Stig n00bie
    48
    Jan 24, 2018
    I wanna join the club... Imma gonna join the club soon, which means I needs infos. ;)
    First off, I've got a 2009-vintage Asus P6T Deluxe, with an i7-920 stabbed into it, and 6gb tri-channel. X58, of course. I just pulled the trigger on a 2tb ssd, and in that discussion thread it has been suggested I go with either a W3680 or an X5670. My little bit of research, and desire for fiscal cheapness, has me leaning towards the 5670; but I welcome any suggestions.
    Also, I understand that my mobo will need a BIOS upgrade: suggestions on what revision and where to get it?
    Thanks in advance...
  17. Bill1024
    Bill1024 Gawd
    988
    Apr 26, 2013
    Just get the latest BIOS right from Asus website https://www.asus.com/us/Motherboards/P6T_Deluxe/HelpDesk_BIOS/
    I would go with the w3680, x5660 or x5675 myself
    The w series are unlocked multiplier and are not limited to the 10 memory multiplier.
    The x5660 will give you the 23 multiplier and 200 x 23 is 4.6. The average OC is 4.0-4.4ghz before needing a lot of voltage and generating a lot of heat.
    X5675 is the 25 x multiplier, I myself like odd multipliers, I have had issued with even multipliers, maybe it was just the boards that I had.
  18. Big_Rig_Stig
    Big_Rig_Stig n00bie
    48
    Jan 24, 2018
    Awesome, thanks.
    I've pulled the trigger on a 5670 for $42 thru Amazon, I think this'll do pretty well. It should clock well with the Hyper 212 cooler I've ordered, shouldn't it?
    Next post: the installation...
  19. Bill1024
    Bill1024 Gawd
    988
    Apr 26, 2013
    You can do 4ghz on air and still have decent temps. I did it with the crappy OEM pipe cooler that came with the 980x CPUs.
  20. Big_Rig_Stig
    Big_Rig_Stig n00bie
    48
    Jan 24, 2018
    I snagged a Hyper 212 for just that job; and, when I'm done with it, it'll be a chilly cooler. :cool:
  21. Big_Rig_Stig
    Big_Rig_Stig n00bie
    48
    Jan 24, 2018
    Oi, forgot to ask: what benchmarks would y'all recommend? I also got the 2TB Micron 1100 SSD from that thread, and it's going in first this weekend, and I'd like to get before & after readings; then rinse/repeat with the processor.
  22. Brackle
    Brackle Old Timer
    7,041
    Jun 19, 2003
    Depends what you want to see for benchmarks. Cinebench, wprime, Blender, Hyper PI. You will be shocked at the performance. @ 4.4-4.6ghz they really do start to shine. I don't even worry about voltage since the CPU's are dirt cheap.
  23. kirbyrj
    22,292
    Feb 1, 2005
    I use that cooler on my X5660 and it works fine at 4.2Ghz with zero issues.
  24. Big_Rig_Stig
    Big_Rig_Stig n00bie
    48
    Jan 24, 2018
    I want to bench the disk setups, WD Black vs. Micron SSD--I know, the ssd will whip up on the WD, but it'll be a fun thing to see.
    Next will be the CPUs, stock 920 vs stock 5670 vs oc'd 5670. Since I'm not doing the vidcard yet, that bench won't be necessary.
    I guess the only other worry will be the RAM, it's almost 10 years old, and I can't remember what kind it is.
  25. RC-Heli-3D
    RC-Heli-3D [H]Lite
    74
    Monday
    Anyone with I/O shield for Sabertooth X58? Intel 1366 socket? I still have mine working like a charm!
  26. Wyodiver
    Wyodiver [H]ard|Gawd
    1,392
    Aug 15, 2004
    Hi all. I have three Dell T3500 X58 boards with bent pins. If you want them, they are yours.
