May 6, 2008 #1 O orion23 Gawd Joined Jun 4, 2004 Messages 879 Hi! I have a 120mm FAN with a 4 pin molex connector with only 2 wires, red and black. Can I cut the wires and join them with the wire of another fan, one with a 3 pin female connector? Thanks!
May 7, 2008 #2 T tzk Limp Gawd Joined Dec 21, 2007 Messages 274 I'm pretty sure you can. Though i'm no electronics expert.. I'll see what others have to say.
May 7, 2008 #3 Z zepper Weaksauce Joined Nov 2, 2007 Messages 77 Yes, you can as long as the total draw of the two fans doesn't exceed the rating of your fan header. I'm assuming you are wanting to parallel the red and black wires of the two fans. .bh.
