10TB WD Easystore + 32GB USB $180
Discussion in '[H]ot|DEALS' started by Deleted member 184142, Nov 8, 2018.
  1. UZ7
    UZ7 Limp Gawd
    170
    Dec 5, 2008
    Got one from Best Buy when it was $169 w/ the 32GB flash drive.
    So far so good, doing a Surface test (26 hours).
    10TB Easystore WD100EMAZ-00WJTA0
  2. ///AMG
    ///AMG 2[H]4U
    3,159
    Sep 19, 2012
    Bought 8 last time. I need to get 10 more. I’ll have to check tomorrow if it’s still available.
  3. odditory
    odditory [H]ardness Supreme
    5,570
    Dec 23, 2007
    You need to casually go buy 100TB like no big deal?
  4. Spartacus09
    Spartacus09 [H]ard|Gawd
    1,059
    Apr 21, 2018
    Thats pretty standard I bought 9 during the January deal, why are you weird and only buying one or two :p?
    d50man likes this.
  5. ///AMG
    ///AMG 2[H]4U
    3,159
    Sep 19, 2012
    I need it, what can I say?
  6. elite.mafia
    elite.mafia Broke Back [H]
    11,565
    Aug 23, 2004
    I ordered one from best buy for next day shipping, $148.74 after tax. Not bad for 8tb
  7. odditory
    5,570
    Dec 23, 2007
  8. drescherjm likes this.
  9. blade52x
    blade52x 2[H]4U
    2,980
    Sep 9, 2006
  10. 86 5.0L
    86 5.0L [H]ardness Supreme
    6,832
    Nov 13, 2006
  11. 86 5.0L
    6,832
    Nov 13, 2006
    Nvm looks like the promocode is dead when the box doesnt show up
  12. Yep. You normally put it in when you go to the cart.
    No promo code box now.
  13. Joust
    Joust 2[H]4U
    2,925
    Nov 30, 2017
    That's a lot. The Plex is strong with this one.
  14. ///AMG
    ///AMG 2[H]4U
    3,159
    Sep 19, 2012
    My Plex is only 2-3 tb. The rest is family videos and pictures, computer back ups for my whole family, (this is probably the largest one probably 8tb total) and files for my consulting side business.
  15. Edgar
    Edgar 2[H]4U
    2,562
    Jul 24, 2005
    My plex is a modest 30tb and growing. I’ve decided to only buy 10tb+ from now on though.
  16. Joust
    Joust 2[H]4U
    2,925
    Nov 30, 2017
    16x4tb here. Next time I upgrade, I will use 8 or 10tb drives. I would like the price to drop just a bit more on them. I don't want to shuck a bunch of drives.
  17. lightsout
    lightsout Gawd
    933
    Mar 15, 2014
    You guys got me beat, I am only add 3x8tb with 4x2tb for redundancy in snap raid. Odd setup I know, but I upgraded from 2tb drives. This has enabled me, at least for now to not have to buy a 8tb and not use the space because its a parity drive. Would love to get a few more. But I have 10tb free and filling it slowly.
  18. Hashiriya415
    Hashiriya415 [H]Lite
    104
    Mar 17, 2019
    What gains are there when using 7200rpm over a 5400?
    For most part I'm planning to store media to watch. Might do light video editing but I guess that would use primary SSD. I'm trying to understand what circumstances do you go for 7200?..
  19. alaricljs
    alaricljs Limp Gawd
    271
    Apr 6, 2011
    You gain a small number of iops. So it's only truly meaningful when you have a large enough number of spindles and an appropriate raid layout where that small number aggregates into a meaningful value.
  20. Hashiriya415
    104
    Mar 17, 2019
    Can you please explain it in simpler English for me? :happy: I don't understand a single thing.
  21. Spartacus09
    1,059
    Apr 21, 2018
    Basically when you use raid it can provide increased performance because while the small speed increase of 15-20Mbps in a single drive is negligible, linking 5+ of the faster drives in raid can be a substantial performance difference.
  22. Hashiriya415
    104
    Mar 17, 2019
    I was reading it like "if the hard drive has enough spindles". No wonder I couldn't understand it.
    But running just one and using it 95% for just playing movies. 5400 vs 7200 wouldn't show any difference?
  23. arnemetis
    arnemetis 2[H]4U
    2,684
    Aug 2, 2004
    You will notice no difference at all, even witrh 4k files.
  24. rmd3003
    rmd3003 Limp Gawd
    318
    Apr 15, 2005
    In your case ("store media to watch") there will be no difference at all. 5400 is more than enough. Well, unless multiple people access your media at the same time.
  25. Hashiriya415
    104
    Mar 17, 2019
    Two people might watch at same time. Three would be super rare.
  26. arnemetis
    arnemetis 2[H]4U
    2,684
    Aug 2, 2004
    If you're using something like Plex to do this, I think you'll be fine. It queues up chunks of data at a time, rather than stream the little bit of data constantly. Make sure you keep the plex media server program data on an ssd, and you should never have problems. Also a good idea to keep the transcode directory on another drive (mechanical not ssd,) but not as important. Your internet upload speed will likely be a limiting factor long before the drive's capabilities.
  27. ND40oz
    ND40oz [H]ardForum Junkie
    11,444
    Jul 31, 2005
    I'd recommend not keeping your transcode directory on an SSD. That's the only way I've ever killed one but it did still last 6 years. If you do go that root, dedicate one to it so when you do have to replace it, it's a simple swap with nothing else installed on that drive. Doesn't have to be large, but the writes will eventually kill it.
    arnemetis likes this.
  28. Edgar
    Edgar 2[H]4U
    2,562
    Jul 24, 2005
    Where do you change the transcode directory?
  29. ND40oz
    11,444
    Jul 31, 2005
    Settings - Transcoder - Transcoder temporary directory
  30. Spartacus09
    1,059
    Apr 21, 2018
    Settings->transcoder and then change the temp directory.
    I gave my plex 64 gigs of ram so I could allocate a 48gb ramdisk transcode directory, thats on top of being SSD base, it queues and plays insanely fast.
    (it also keeps transcode from eating up writes on my SSD)
  31. arnemetis
    arnemetis 2[H]4U
    2,684
    Aug 2, 2004
    You're absolutely correct, I did not make that clear. The transcode directory works just fine on a mechanical drive, it's what I myself do. Just the Plex Media Server data benefits from being on an ssd. I edited my post to clarify.
    ND40oz likes this.
  32. Hashiriya415
    104
    Mar 17, 2019
    How do you guys have this setup? Like what kind of build do you have? I feel like I should start another thread for this.?
  33. Joust
    Joust 2[H]4U
    2,925
    Nov 30, 2017
    Yes.
    Hashiriya415 likes this.
  34. Fritzz
    Fritzz Gawd
    735
    Feb 11, 2008
    If you make one link it. Wouldn't mind seeing how others have Plex setup too.
  35. Spartacus09
    1,059
    Apr 21, 2018
  36. UZ7
    UZ7 Limp Gawd
    170
    Dec 5, 2008
    Penguincomp likes this.
  37. Penguincomp
    Penguincomp Racer [H]
    10,254
    Sep 4, 2004
  38. rmd3003
    rmd3003 Limp Gawd
    318
    Apr 15, 2005
    Interesting what's inside of "Elements" - red, white, blue? "Easystore" 10TB has white drives inside.
  39. ND40oz
    11,444
    Jul 31, 2005
    Been trying to order for the past few hours, can't get shoprunner to work...and out of stock. Typical Newegg.
  40. Jim Kim
    Jim Kim 2[H]4U
    3,500
    May 24, 2012
    Typical in what way. I have ordered 10's of thousands worth of computer parts from Newegg. If you mean typical in that I get what I ordered and have returned wrongly ordered parts w/out issue. shrug
    But if you mean you're having an issue or they are having an issue or "Shoprunner" is having an issue.. ... .. shit happens
    If people could not order from newegg I doubt they'd still be in business.
