10TB WD Easystore + 32GB USB $180
Discussion in '[H]ot|DEALS' started by Deleted member 184142, Nov 8, 2018.
  1. Blazestorm
    Blazestorm [H]ardness Supreme
    6,940
    Jan 17, 2007
    Most of the BestBuy sales have been pretty short, I setup Slickdeals alerts for it, waiting for 8TB @ $130
  2. Donnelltech
    Donnelltech [H]Lite
    80
    Sep 11, 2004
    I just got an email from Bestbuy with early access for the president's day sale and the 10TB with 32GB Flash drive are at $169.99. I'm currently chatting with an agent to get my price adjustment from the ones I bought 2 weeks ago.
  3. kirbyrj
    kirbyrj [H]ard as it Gets
    24,458
    Feb 1, 2005
    I guess I'll have to wait for the sale to go active. I didn't see early access in my e-mail...oh well.
  4. Donnelltech
    Donnelltech [H]Lite
    80
    Sep 11, 2004
    Its posted on Slick Deals as well. I just had to sign in to my account to see the pricing.
    kirbyrj likes this.
  5. chizow
    chizow Gawd
    870
    Jan 23, 2007
    Yep this is a My BestBuy Early access for Elite/Plus members, but it should go live for everyone starting tomorrow. Don't overlook the 32GB EasyStore drives either, which are really just rebadged Sandisk Cruzer Glides. Great for your Windows Media Creation tools Win10, Server 2016, entire bootable OS etc.
  6. Spartacus09
    Spartacus09 [H]ard|Gawd
    1,060
    Apr 21, 2018
    Confirmed I'm elite plus from all the 8TB drives I bought last year :p
  7. kirbyrj
    24,458
    Feb 1, 2005
    Now I got it. Thanks. Picked one up. $180 with tax.
  8. mlcarson
    mlcarson Limp Gawd
    314
    Jul 12, 2009
    $183.59 with tax here in tax crazy Kalifornia. Not sure if I needed but worse case, it replaces 3x3TB older HDD's.
  9. kirbyrj
    24,458
    Feb 1, 2005
    Mine arrived yesterday and it has a rattle inside the enclosure. What a PITA. I plugged it in anyway and am testing it to see if the drive is good as I'm just going to shuck it anyway.
  10. rmd3003
    rmd3003 Limp Gawd
    318
    Apr 15, 2005
    It's still $169 as of now. Interesting that many stores around are out of stock. Maybe BB just unloading them. It's just too low.
  11. Spartacus09
    1,060
    Apr 21, 2018
    Possible, but its a new product too.
    Maybe they’re selling out the combos with the flash drive to make room for a package with just the drive.
  12. Edgar
    Edgar 2[H]4U
    2,562
    Jul 24, 2005
    Is a 10TB supposed to show up as 9.09tb in windows?
  13. Spartacus09
    1,060
    Apr 21, 2018
    After formatting that sounds about right 9.0949TB ~ 9313 gigs
  14. Absalom
    Absalom Gawd
    676
    Oct 3, 2007
    Yep, they are still advertising in multiples of 1000 instead of 1024.
    So, 10TB in marketing terms = 10 * 10^12 bytes.
    1 TB by any legit OS will be calculated as 1024^4 bytes.
    So divide 10 * 10^12 by 1024^4 and you get 9.094957.... TB.
    So, yes, Windows is correct.
  15. It's not from formatting, and it's not marketing. It's SI units, which is a IEEE/IEC standard manufactures follow. Decimal vs Binary, SI units are base 10, while Windows uses Binary which is base 2.
    IEC Prefixes.
  16. Spartacus09
    1,060
    Apr 21, 2018
    I didnt say it was due to formatting, not disagreeing with you, but thats the usable space...after you format it :p thats kinda required to be able to use it in windows.
  17. nightfly
    nightfly 2[H]4U
    2,341
    Jun 7, 2011
    So, what file system will give us 10TB out of that 10TB device? And is it something we can actually use, say, on a common NAS? Or is the 10TB just like a quarter pound hamburger, but only if you eat it raw will you ever get a quarter pound of meat out of it?
  18. GamerAddict76
    GamerAddict76 n00b
    10
    Jan 23, 2019
    You will always lose some in the formatting. Just like your quarter-pounder.lol
  19. kirbyrj
    24,458
    Feb 1, 2005
    I figured out what was rattling inside mine. The one plastic clip holding the mounts snapped off. I snapped it back in and it's good as new (for another drive since I shucked that one).
  20. Read the link I posted. You are not losing or gaining space, the size on disk does not change. In SI units it's base 10, so 1000 bytes to a KiB, 1024 bytes to a kB. What you are doing is looking at them as the same, which they are not, it's like seeing a ruler and wondering why one person says it's 12in and someone else claims it's 30cm. There is no actual reason to use base 2 for HDD, for other memory types such as RAM it's addressed by physical binary address, so using base 2 is a natural fit. Some Linux uses base 10 for HDD and network and base 2 for RAM etc, iOS also does this, Windows however uses Base 2, so 1024 sizes for the file system.
    Nothing is lost. :banghead:
  21. nightfly
    nightfly 2[H]4U
    2,341
    Jun 7, 2011
    Okay, okay, nothing is lost. I just wish MdDonalds would stop formatting my quarter pounders in base sixteen, because I KNOW I'm losing something there.
  22. UnknownSouljer
    UnknownSouljer [H]ardness Supreme
    5,956
    Sep 24, 2001
    Can anyone comment on the performance of these drives? Looking for a cheap massive options to RAID and video edit off of.
  23. Blazestorm
    6,940
    Jan 17, 2007
  24. SolidBladez
    SolidBladez [H]ardness Supreme
    6,274
    Jan 4, 2008
    Mine get about 220 MB/s sequential read and write. With software RAID-0 (Windows) I get nearly double that. If you use them in the USB 3.0 enclosure your random writes and reads will suffer a bit.
  25. UnknownSouljer
    5,956
    Sep 24, 2001
    The plan is this:
    https://www.amazon.com/dp/B076C72RX2/ref=cm_sw_r_cp_api_i_DTnCCb97RXG1J
    And probably software raid 5. If I can afford more than one enclosure, I'll probably run one with straight raid 0 across the four drives.
  26. odditory
    odditory [H]ardness Supreme
    5,570
    Dec 23, 2007
    There was around an hour last night where WD Elements 10TB was $145 at B&H with limit two, but I found it too late - right as the SD droolers had run it out of stock. Then price went to $159.99 with backorder. I believe it can still be backordered for $159.99
    https://www.bhphotovideo.com/c/product/1433062-REG
    To my knowledge, lowest they've ever been.
  27. odditory
    5,570
    Dec 23, 2007
  28. Edgar
    Edgar 2[H]4U
    2,562
    Jul 24, 2005
    Would these be ok for Plex. Would be a lot of reading. Not much writing.
  29. drescherjm
    drescherjm [H]ardForum Junkie
    14,475
    Nov 19, 2008
    They would be great for Plex. I would keep them as externals until at least the warranty expires.
    Must resist. Must resist...
  30. Livewyre
    Livewyre n00b
    13
    Feb 23, 2016
    Im in for 2 at this price.
  31. arnemetis
    arnemetis 2[H]4U
    2,684
    Aug 2, 2004
    As long as you're careful shucking them, no reason to not just keep the external enclosures in a box for warranty purposes (this is what I did with the 8x in my server.) If I have a failure, it will be easy enough to put it back into the enclosure, I didn't do any damage at all to any of my enclosures.
  32. Spartacus09
    1,060
    Apr 21, 2018
    This, I shucked all 12 of mine with no issue and have the enclosures in a box in my garage.
    kirbyrj likes this.
  33. rmd3003
    rmd3003 Limp Gawd
    318
    Apr 15, 2005
    So what is inside of 10TB Elements? I know 10TB Easystore are white drives.
  34. NGX
    NGX Gawd
    563
    Oct 6, 2006
    They are also whites. People are reporting getting either WD100EMAZ-00M9AA0 (air filled) or WD100EMAZ-00WJTA0 (helium filled).
  35. rmd3003
    rmd3003 Limp Gawd
    318
    Apr 15, 2005
    Both amazon and B&H are backordered. People are like locust - a few minutes and everything is gone ;)
  36. asheron42
    asheron42 n00b
    13
    Feb 16, 2013
    I've shucked several of these, haven't gotten a helium filled one yet.
  37. ND40oz
    ND40oz [H]ardForum Junkie
    11,444
    Jul 31, 2005
    I've have 1 Easystore from Best Buy and 3 Elements from Amazon and they've all been WD100EMAZ-00WJTA0.
  38. odditory
    5,570
    Dec 23, 2007
    Lateralus, rmd3003 and eclypse like this.
  39. rmd3003
    rmd3003 Limp Gawd
    318
    Apr 15, 2005
    LOL - Walking Shuckers (Season 2019)
    Lateralus and eclypse like this.
  40. Makeroflostsouls
    Makeroflostsouls 2[H]4U
    2,547
    Jun 4, 2008
    I picked up 2 on the b&h deal. Back ordered but all well. Server is down right now as I just moved any way.
