1080ti with 4770k and 650 watt PSU?
Discussion in 'Video Cards' started by Will V, Sep 18, 2017.
  1. Will V
    Will V n00b
    17
    Sep 18, 2017
    As the title states, I have a 4770k, no OC at the momnet, And a 650w PSU. I'm worried that A: 4770k will need to be upgraded and B: the PSU doesn't have the horses to keep everything going. Any help would be ppretitated
  2. ssnyder28
    ssnyder28 2[H]4U
    3,574
    May 9, 2012
    What is the model of the 650w PSU? If its anything decent then you should be ok even with an OC on the 4770k.
  3. Dan
    Dan [H]ardness Supreme
    7,504
    May 23, 2012
    your fine, Im running a ryzen 1700 @ 3.8ghz and a OC'd 1080 on a 550w. if its a decent PSU your fine
    Flogger23m likes this.
  4. Will V
    Will V n00b
    17
    Sep 18, 2017
  5. drklu
    drklu 2[H]4U
    2,212
    Jul 15, 2013
    I am running a 1080ti and 4790k on a 450w psu so you should be good.
  6. Will V
    Will V n00b
    17
    Sep 18, 2017
    Thanks for the info, good news as I can buy my 1080ti earlier.
  7. ssnyder28
    ssnyder28 2[H]4U
    3,574
    May 9, 2012
    Ultra is an OK psu brand, not really high end but should be good enough for what you need.
  8. Digital Viper-X-
    Digital Viper-X- [H]ardForum Junkie
    13,760
    Dec 9, 2000
    I have 650W corsair PSU powering my 6700K @ 4.6 and 1080, should be fairly close in power.
  9. samm
    samm [H]ard|Gawd
    1,757
    Jul 17, 2013
    Dont know if its worth anything, since i bought into the long warranty, 80 plus gimmicks, and oversize PSU gimmicks but I think EVGA has a power meter to see whats required. Input your build, and it will spit out a power min
  10. p_monks33
    p_monks33 [H]Lite
    118
    Jul 3, 2012
    I doubt you will have any issues. My 4770K @4.7 , and a 1080TI pull slightly over 500 at the wall.
  11. misterbobby
    misterbobby 2[H]4U
    3,814
    Mar 18, 2014
    What you are doing is downright stupid. If you are overclocking at all then you are pushing that psu to its limits.
    Yeah right around 500 at the wall from me too in the really demanding games.
  12. _mockingbird
    _mockingbird Gawd
    992
    Feb 20, 2017
    NVIDIA recommends a 600W power supply unit so you are good.
  13. Nebulous
    Nebulous [H]ard|Gawd
    1,406
    Nov 16, 2005
    A 600w quality unit, IE Seasonic, Corsair, EVGA, etc. Not a 600w shitbox like the Ultra Brand.
  14. RamonGTP
    RamonGTP [H]ardness Supreme
    7,846
    Nov 9, 2005
    You'll be fine. My system pulls just over 500 watts from the wall on demanding games and that includes a pair of monitors.
  15. USMCGrunt
    USMCGrunt 2[H]4U
    3,113
    Mar 19, 2010
    I'm a bit surprised a PSU company hasn't come along with an integrated power meter that can connect through USB and show real-time power draw.
    Araxie and razor1 like this.
  16. razor1
    razor1 [H]ardForum Junkie
    10,155
    Jul 14, 2005
    yeah that would make it easy have it measure per rail too!
    Araxie likes this.
  17. Araxie
    Araxie [H]ardness Supreme
    6,386
    Feb 11, 2013
    Asus AXi series do have that feature, using corsair link you can see and manage everything in the PSU, including power load by Amperage or Wattage.. And I guess it's also the same for other smart asus PSU series as HXi and RMi
    this is an example
    [​IMG]
    USMCGrunt and razor1 like this.
  18. p_monks33
    p_monks33 [H]Lite
    118
    Jul 3, 2012
    Didn't realize that you could use the Link app for PSU power draw. I switched to an EVGA PSU a few years ago, I wish it had something like that so I could see my PSU stats.
  19. Patton187
    Patton187 Gawd
    668
    Feb 12, 2012
    I'm running a 4770 nonk and a 1080ti. I'm running at 2560 x 1440 and I'm sure I'm not running at absolute max frames, but my experience is awesome.
  20. cybereality
    cybereality [H]ardness Supreme
    4,862
    Mar 22, 2008
    The MasterWatt Maker 1200 has a wireless module you can connect with an app on your phone to monitor stats. I have one but I still have yet to try it out.
  21. magoo
    magoo [H]ardForum Junkie
    14,367
    Oct 21, 2004
    Back in the day, Ultra was one of the first PSUs to offer modular connection and flat "flex-force" cables.
    They were also one of the first to offer a 1000W PSU.
    I owned this one.
    This is what jonnyguru had to say......definately not a POS : http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=41
    That PSU should do OK as long as you don't OC all your stuff too much.
    DanNeely likes this.
  22. RadioDude
    RadioDude [H]Lite
    113
    Nov 7, 2009
    I have a 3770k and I'm still fine with running this card. Games these days aren't very cpu intensive. Don't worry about it.
