1080ti Pre-order, Retail, and AIB availability watch
Discussion in 'nVidia Flavor' started by bluesynk, Mar 2, 2017.
  1. Syphon Filter
    Syphon Filter 2[H]4U
    2,588
    Dec 19, 2003
    That's all there is to it. The absolute power draw and temperature are neither here nor there, all people are interested in is a) how loud is it b) how high will it clock. But as I said, it seems OC headroom is limited from the anecdotal info we have about Pascal cards in general and the 1080Ti Strix review.
    Time will tell I guess, I plan to run my cards stock (no OC) for now but I will tweak the fan curve to see what boost clocks I can maintain. I will report back tomorrow night once I have things installed and setup.
  2. illram
    illram [H]ard|Gawd
    1,332
    Sep 19, 2011
    Nowinstock.com sent me a bunch of alerts today for Nvidia direct, MSI, Gigabyte, and EVGA cards. Snagged one from Nvidia this morning about 2 hours after an email alert, and just got shipping confirmation. Seems stock is replenishing. Canceled my Newegg backorder!
  3. Darkswordz
    Darkswordz Limp Gawd
    439
    Jan 5, 2016
  4. brentsg
    brentsg [H]ard|Gawd
    1,369
    Mar 8, 2003
    I don't doubt that someone will get a PhD studying how much more quickly a gaming room heats up due to current leakage, but up until that PhD, it'll be zero'd out as negligible.
  5. RamonGTP
    RamonGTP [H]ardness Supreme
    7,360
    Nov 9, 2005
    Max OC might be within a few MHz between the cards, but how well does it hold under load? That's where AIB cards set themselves apart from reference, and of course, acoustics.
  6. Ripskin
    Ripskin 2[H]4U
    2,075
    Jan 15, 2004
    Wasn't this thread for stock and purchasing overall and another thread for feedback and owner discussion on the card and its cooling?
  7. RamonGTP
    7,360
    Nov 9, 2005
    Yes, until some people who don't want to wait for AIB cards thought the people who do want to wait for AIB cards are wrong for wanting to wait for AIB cards.
  8. FJC
    FJC n00bie
    59
    Sep 30, 2003
    I was finally able to get one into my cart on nvidia.com a few minutes ago and check out.
  9. Nenu
    Nenu Pick your own.....you deserve it.
    17,878
    Apr 28, 2007
    Something handy ...
    The MSI FE card comes with a click locking DP to DVI adapter.
    I dont know if its dual link or high refresh capable, its not externally active.
    It works great with my HDMI 60Hz 1080p display.
    I previously had this connected via a DVI to HDMI lead.
    Now it goes DP to DVI to HDMI and works fine with no increased lag.
    But the option to change RGB or YCbCr has gone, it now looks like Full RGB permanently (I'm sensitive to this, it is full RGB).
  10. Dan_D
    Dan_D [H]ardOCP Motherboard Editor
    53,438
    Feb 9, 2002
    I will wager that it isn't dual-link capable. Those have to be active to work.
  11. Nenu
    17,878
    Apr 28, 2007
    I agree.
    But I have no clue if it is powered through DP, it could be internally active.
    Unlikely but possible.
  12. Dan_D
    53,438
    Feb 9, 2002
    That would be heading into proprietary territory. I think that's unlikely but certainly possible.
  13. fwrigley
    fwrigley [H]Lite
    67
    Oct 2, 2011
    Gigabyte's FE card also includes the same adapter FYI.
  14. Dan_D
    53,438
    Feb 9, 2002
    My NVIDIA branded FE cards came with that adapter as well.
  15. Syphon Filter
    2,588
    Dec 19, 2003
  16. Nenu
    17,878
    Apr 28, 2007
    Found the downside, no audio.
    This would have been easy to implement unless they need the pins for Dual Link.
    Hmmm.
    Unfortunately I dont have a method to test here.
  17. RamonGTP
    7,360
    Nov 9, 2005
    Has DVI ever supported audio? Dual link or otherwise?
  18. Dan_D
    53,438
    Feb 9, 2002
    No. HDMI is essentially an extension of the DVI specification that does carry audio.
  19. Nenu
    17,878
    Apr 28, 2007
    Yes for a long time.
    Some of the dual link pins on the gfx card have been repurposed to feed audio into HDMI out.
    ie
    http://nvidia.custhelp.com/app/answ...-will-audio-be-transmitted-over-this-cable-to
    Every gfx card I have had since after my GTX260 has been able to do this.
    I've been using it for years.
    I was using it earlier this week with my 980ti until I popped in the 1080ti with its new DVI adapter.
  20. Dan_D
    53,438
    Feb 9, 2002
    I didn't know that. Interesting. That doesn't look like it's part of the actual DVI spec but rather something NVIDIA did to make it so you could use the DVI port as an HDMI port with full audio capability.
  21. MorgothPl
    MorgothPl 2[H]4U
    3,065
    Oct 13, 2008
    Looks like it's not only MSI - my evga came with same adapter. It's either NV standard to offer that in box, or just manufacturers decided to offer that on their own.
  22. jmaker
    jmaker Limp Gawd
    396
    Dec 14, 2005
    Can anyone comment on the noise factor on these cards? I currently have a 980ti and it was much quieter than my previous 290x. That thing was loud. But I like the 980ti as far as noise level.
    My question is, should I wait and save up my pennies for the Asus Strix or are these Founders Edition cards comparable in noise levels to the 980ti? I have a 1440p Ultrawide monitor. Would it be a waste of money to buy that Asus Strix card instead of these cards that you guys are getting now?
  23. pandora's box
    pandora's box [H]ardness Supreme
    4,340
    Sep 7, 2004
    Card is quieter than the 980Ti stock cooler, but not by much. If you use a custom fan curve on the card - 65% gets to be very comparable to 290X reference cooler levels.
    jmaker likes this.
  24. doug_7506
    doug_7506 2[H]4U
    3,099
    Oct 17, 2004
    Definitely wait for the Strixx if you are worried about noise. Two bigger fans and more heatsink area will provide for a much quieter experience.
    jmaker likes this.
  25. RamonGTP
    7,360
    Nov 9, 2005
    The strix is 6db quieter while being 15c cooler. Both those numbers are quite significant. I say wait. That's what I'm doing.
    jmaker likes this.
  26. wuzupfoo
    wuzupfoo Limp Gawd
    302
    May 11, 2010
    Back on topic. In stock at nvidia. Just snagged one finally! Well they took my order hopefully it goes thru.
    Ziontrain likes this.
  27. Ripskin
    Ripskin 2[H]4U
    2,075
    Jan 15, 2004
    Amazon charged my card last night, still says shipping on the 21st so we'll see.
  28. Fixall
    Fixall [H]ard|Gawd
    1,316
    May 17, 2011
    They don't charge until they plan on shipping, so I imagine it should be on it's way. :D
  29. misterbobby
    misterbobby 2[H]4U
    3,145
    Mar 18, 2014
    That is what they claim but its simply not always the case as they have charged my card sometimes several days before an item is shipped.
  30. KickAssCop
    KickAssCop [H]ardness Supreme
    6,454
    Mar 19, 2003
    When the AIBs out. This FE is burning my ears.
  31. heatlesssun
    heatlesssun Pick your own.....you deserve it.
    48,326
    Nov 5, 2005
    No problem when not overclocked, but yeah, problem when overclocked, at least two of them. One OCed isn't bad at all. Thinking about an hybrid cooling solution but there's not a lot need to overclock these puppies in games that support multiple-GPUs even at 4k, most will blow past 60hz without overclocking.
    But sure, if you want top performance and not a lot of noise especially in SLI, you'll want an AIB solution that doesn't have the noise the FEs do.
  32. Darkswordz
    439
    Jan 5, 2016
    Finally!!! :ROFLMAO:
    [​IMG]
    I have an issue though. I'm using the DVI to Display Port adapter to run my U3011 but now I'm only getting 1600x1200 max resolution instead of 2560x1600. When I was just using my DVI cable on my 980Ti I was able to run the full 2560x1600. Any idea how to fix?
    heatlesssun likes this.
  33. Merc1138
    Merc1138 [H]ard|Gawd
    1,851
    Sep 25, 2010
    Yes, you need an active dual link DVI adapter. The one they provide is a passive adapter.
  34. Nenu
    17,878
    Apr 28, 2007
    Max res 1920x1200 when not a certified active adapter.
  35. Azrak
    Azrak Gawd
    610
    Oct 4, 2015
    Ditch the DVI, switch to DP. That's what I did.
    Bandalo and heatlesssun like this.
  36. heatlesssun
    48,326
    Nov 5, 2005
    Yeah, even a good active adapter may be quirky, I bought 3 at $90 a pop last year when I went to two 1080s without only 2 DVI ports but three monitors and to use 3d Surround they all had to be connect through DP. Kind of a waste of money unfortunately. Moving to native DP fixed all of the quirks.
  37. Darkswordz
    439
    Jan 5, 2016
    Well crap, any recommendations on a good one? Best Buy seems to only have passive single link ones.
  38. heatlesssun
    48,326
    Nov 5, 2005
  39. Merc1138
    1,851
    Sep 25, 2010
    Yeah, spend the $10 instead on a DP cable if your monitor supports it.
  40. Nenu
    17,878
    Apr 28, 2007
    Well dur, you think he would be having this conversation if...
