OblivionLord
- Apr 16, 2004
I'm not concerned about the visual difference from 720 to 1080 at a certain distance. My question is, if 1080p rips naturally have higher bitrates then wouldn't you see a quality difference just in that itself compared to the lower bitrates in 720 variants if both are done from the same group?
For instance...
A.Fistful.Of.Dollars.1964.1080p.BluRay.x264-CiNEFiLE
Video.......: x264 @ 10500 kbps
A.Fistful.Of.Dollars.1964.720p.BluRay.x264-CiNEFiLE
Video.......: x264 @ 5425 kbps
For instance...
