mista ting
- Apr 13, 2006
need and LCD that has these specs
1080P
IPS
HDMI
going to use for PS3 and PC and HDMI Receiver
1080P
IPS
HDMI
The Dell U2311H would be a good choice. Its 1920x1080 and IPS. You would need to use an HDMI --> DVI cable though, but those are cheap and plentiful.
Keep in mind with the converter you lose the sound component with hdmi. You'd need to then output sound from component (no surround?) or optical from the PS3. At least this is what I understood while researching this based on a possible future PS3 purchase, someone who owns the system might be able to shed more light on this. I'm assuming that he asked specially for hdmi due to this requirement?
+1, or the U2211H for slightly cheaper. same resolution, 1.5" smaller.
I don't know how the U2410 or the U2711 will scale as they're both 16:10 monitors.
I believe the U2711 is 16:9.
Yep. He must have been thinking of the previous 2709W, which is a 16:10 PVA monitor known for its 45-60ms input lag.
