yes, should be, I don't have a 1080, but I got a 1070, has dp, hdmi, dvi ...run dp to dvi, dvi to dvi, and hdmi to tv
actually it has a few more ports then that, like...3 hdmi... dp, dvi... but ya
If you mirror the displays, it will use the lowest res on both, you want to use extended desktop if you want individual resolutions.I bought a new cable, so apparently the first one was bad. DP connected to a G-sync monitor, all is fine. HDMI connected to a UHD TV mirrors the monitor and its resolution which is 1440p. Is there a way to have the monitor at 1440p and the TV connected through HDMI at 4k?
