Sturmangriff
- Nov 30, 2008
I have decided to upgrade my 780 Lightning with a Zotac 1080 Amp Extreme but there may be a problem. My case is a Corsair Air 540 which has a listed max gpu length of 320mm. The 1080 Amp Extreme is listed at 325mm but after doing some measuring it looks like it will fit...barely. I did replace the stock 140mm fans with Corsair AF120mm so maybe I picked up a few mm with that change? Here is my measurement with the 780 Lightning in the case which is 295mm. It looks like I will have a little over 5mm to spare. Have I overlooked anything or do you guys think I will be ok? Thanks.
