why are you set specifically between those cards?. price?. I would not look at anything less than a GTX 1080 for gaming with that kind of setup. if gaming isn't your primary concern, then always buy the newer tech, which in this case is the GTX 1070, never play de "waiting game" as always there's something better around the corner that will "worth" the waiting, buy the best you can afford now.
Sigh, I can afford anything, but im just being a miser and wanting to make sure I get the best bang for my bucks.Your setup is 3/4 of 4k. Close enough to need the vram. I'm running over the 4GB mark now at 1440p, and you have more pixels to push with your setup. Get the most vram you can afford.
If you are in no hurry then I would wait for the rx500 and vega. Not because they may be a good buy, but because they may be strong enough cards that may force nvidia to adjust pricing again. Other than that - it depends on what you expect of your setup. I had a 980ti driving a 3440x1440, which is nearly the same pixel count as your setup. The 980ti dealt quite well in most games, but some games (like the newer Tomb Raider) barely kept at 60fps, sometimes dropping to 40-50. I replaced it with a 1080ti and it's all good now . It depends on what you play and what you expect. If you want to use all 3 monitors and see all 144fps at ultra or very high settings - you will need something better than a 1070 or even a 1080. If you are fine playing on medium/high settings, low AA - the 1070/980ti would probably be enough.
I would look up the game performance on the cards you want to buy at 1440p or 3440x1440 resolutions and take it into consideration.
980ti is from 2015
So basically,
I run a 3, 24inch monitor setup (1080p/60hz for sides, 144 hz primary) with a GTX 680 MSI Lightning
Which card should I grab? or should I wait to see how the new RX 500 series does? I'd rather stay Nvidia
Just wanting opinions!
Yea, that value is pretty insane.I'd grab one of those $420 1080s from Newegg in their Ebay store. Great bang for the buck if you ask me.
I bought the Gaming Z 1070 for $330 from ebay
Seems to be working great. My only issue is... 1 DVI port... all my monitors are DVI/VGA. They were purchased ~3 years ago too heh
Yeah, I gotta find some DVI > DP adapters --- the active DP adapter I have is killing my side monitor heh.If they are only 1920x1080 or 1920x1200 just get some DP -> DVI adapters.
I went ahead and got a 1070 Gaming Z MSI card.Newegg has sales on 1080s on eBay. Last week or so they had 2 different models for $420 or so. Check to see if that happens again. Give yourself a time window and if sale doenst happen in that time buy what you feel the best deal is. Anything less than 450 for gtx 1080 is a great deal.
