With my H100i I can get a stable overclock of 4GHz out of my Phenom II x6 1045T - 50% overclock, I'll take it. Reminds me of the 300a days.
Only problem I have is that ArmA2 crashes...I play DayZ mod quite a bit and it is more than frustrating to gear up and have my PC crap out on me, and with ArmA2 being so CPU-intensive the 500MHz I have to drop to keep running does have a noticeable effect on FPS. I'm not stressing the RAM or NB/HT, voltages and temps are superb (1.4v, CPU under 55° at load)...any ideas? With the speeds I can get out of this chip, anything but an 8350 is a side-grade at best, plus the engine doesn't take advantage of much over 4 cores...should I start disabling two cores and trying higher clocks?
EDIT: Misspoke right off the bat, it's a 1035T not 1045T.
