1005ha batteries interchangeable?
badbadtz560
Does anyone know if you can purchase a 1005ha-p battery and stick it in a 1005ha-e series? or even a 1005ha-v battery and stick it in? It seems that the higher quality battery on the 1005ha-p has a different voltage than the other models.. but all the other models seem to have the same voltages.
Did anyone else try purchasing a lower end model and purchase a longer lasting battery?
I am not concerned w/ the n280 processor or bluetooth differences. I basically purchased the newegg deal and wanted to know if I can do anything to improve its battery life by purchasing a 6-cell battery of some sorts.
crazycd1
You should have no problem with changing out the battery to the 6 cell. I have not personally tested it on a 1005 series, so maybe wait for someone to confirm this.
badbadtz560
It looks to me as they are interchangeable. If I were to post again, the next question would be.. what websites would sell reliable 6-cell batteries that actually give you the rated mah >_<
thx for the help
