1000D Dual Loop - 360mm AND 120MM on fronts
lopoetve
So building a dual system in a 1000D. Alphacool or EK radiators, haven't decided yet (probably EK block, AC rads), but either way, I know I'm going with a 420MM up top, and then I have 480MM of space up front.
What I'd LIKE to do, since I have two systems in there, is split the rad space up front.
System 1 - 10980XE, 6800XT. I want to feed this the top 420 and dual 360MM up front. Overclocked some, but aiming for QUIET.
System 2 - 8 Core consumer intel, integrated graphics, SAS controller with a bunch of drives. I want to feed this 2x120mm up front (the remaining slot in the front). Stock speeds, but aiming for as quiet as possible.
Question: Is there going to be spacing problems trying to do 2 radiators (360mm+120MM) in a spot designed for 1x480mm? What I mean - the radiator is a certain size, and then most have the ports below the "space" - how much conflict will I ahve, if the bigs have the ports up top, and the small have the ports at the bottom?
Basically, can you sanely stack radiators next to each other (linearly), or is there extra space that's going to cause a conflict?
360mm. 120mm
Like that.
Shadowarez
I have the same case but I'm moving to a Asus DH when I can get my hands on a 5950x. I have the 480 mount up top with the 420 in front I'm thinking duel 480s uptop and duel 420s up front.
System 1 is the 7980xe other will be a itx beast with drive's and what not to be my Nas when can get my hands on good AMD parts.
lopoetve
That's pretty much what I"m doing system wise, only doing intel for the ITX because integrated video (can't buy APUs right now it seems...). Need the SAS card in the one PCIE slot.
edit: And intel = TB ports, so I can use TB 10G nics.
Shadowarez
odly enough i found duel prot 10gb intel nics on ebay that use rj45 ports, i bought 2 for $80 which i thought couldnt be real but they work great,
im looking into these LSI AVAGO NYTRO NMR8110-4i since my nass will basicly be 4 14tb drives i wanted to make sure they got some serious cache to work with.
my first rig had a 360 aio i did not like the fact it had 1 open spot, lol
Current Rig
lopoetve
Current Rig
Only have one PCIE slot though, and that's for the SAS controller. The thunderbolt ports are fast enough for 10G nics :). No ITX boards that have 10G built in that I've found, except actual true server boards - and that changes a lot of the game to be honest.
Shadowarez
did you get different fan grills mine only came with 480s, and 420's id figured id be stuck having to use those to build out the loop.
lopoetve
Nope, 480 in front (x2) and 420 up top.
That's the part - 480 = 360+120. Can I split that space like that, or is there too much "overhead" around the radiators for it to fit (assuming orientation is inverted).
lopoetve
Like that. Right side is the frame. Then 4x fans. Then two radiators, split 120mm/360mm. Can you do that?
lopoetve
That's the question - the two non-port ends of the rad, are they narrow enough for that to work, or is the overhang / design not going to fit?
D-EJ915
End tanks of rads are too big to fit them like that. Usually the shrouds on the sides are too big to put them directly next to each other too but that might work better.
tunatime
Well...OK
why not just do 2 pumps with a common res 420 up top 2 480s in the front. pump 1 comes on anytime any of the 2 pc have power and pumps though all the rads and the weaker system blocks and pump two just though the main system. get a good fan controller and both systems will have better cooling and you wont hear them if you tune the rpms to water temp
I dont know of any 360 rads with end tanks that will allow you to fit another 120 under it. Youll probably have to go with dual 480s in front (like tunatime suggests) and run the 420 and a 480 for the primary system. Then the second 480 for the secondary system.
You could also opt for 360s up top/480s in front and run the secondary system off of one of the 360s or vice versa.
lopoetve
So single res with 2 pumps pulling off of it? You can do that?
Enigma
Use one of these and a res of your choice to feed the dual pumps... this is not that only option there are alot of ways to get it done out there.
lopoetve
Also doesn't really say what that thing DOES? What does it do? Other than give you a place to put a couple of pumps...?
OOOHHHH
You run res -> both pumps -> loops -> back to res?
Enigma
OOOHHHH
yep that is the way it works you run the loops in parallel and then back to the same res
