I am looking in to get in to multi core and multi processors systems again. Well the first time I wanted to do it, I was looking in to a 4p folding machine and it ended up being too pricey for me so I did not go thorugh with it. I was looking around ebay and started seeing these cheap servers like
http://www.ebay.com/itm/HP-BL685c-S...509340?pt=COMP_EN_Servers&hash=item5af3183fdc
or a Del 1650 version of these things. They are usually 5-8 years old, have small hard drives in Raid configuration come with anywhere from 1 to 4 cpu's (xeon, opteron) and a good amount of ram.
My purpose is to learn server enviroment, maybe run my own server from home for simple older games like counter strike or communication software like ventrillo or mumble. I will not be doing any bitcoining or folding, I just want to have the cool factor of having a multi processor server at home and play around with it.
Questions:
1) I think these blade style servers need enclosures? Can I run them on their own?
2) What do you guys thing about single core 800FSB Xeons. I can get a system that has two of these but is it going to be much more different than a dual core single cpu?
3) I would much rather have a 4p 4core system (AMd or intel) just to see how it works, do some parallel programming on it and learn how to shift load from core to core, what are my options?
4)I know this is a vague question but what is the cheapest way to build a 4p system like a normal server box not these blade things. I am totally open to used and not top of the line stuff as long as they still work. I would definitely want 4 processors (2 minimum) , a raid hard drive setup( SSD or 10k+), min 8 gigs of ram and a means to project all these on a screen with about 720p or so resolution.
Questions:
