- Aug 20, 2006
Samsung’s latest Galaxy phones have finally been officially unveiled. Those of you looking to upgrade should be happy to know that each has a bigger battery, better cameras, waterproofing, as well as the return of SD card support.
Samsung has tightened up the S6’s overall design for the S7: it’s more comfortable to hold, easier to pick up off of a table, has a flatter fingerprint scanner, and has a less pronounced camera hump. It won’t look unfamiliar to anyone that’s seen or held the S6, and it still looks remarkably similar to the iPhone 6 and 6S depending on which angle you look at it from. The standard S7 retains the 5.1-inch, quad HD Super AMOLED display from its predecessor.
