VA panels was not good for gaming. They have terrible artifacats on black backgrounds.
I have an EIZO FlexScan 2231W S-PVA and is great
Greetings
The black artifact is dark overshoot.
The blacks will never look deep because the bezel is so dark due to the glass on the black bezel. My Dell has a 0.13 black level & my CrossOver does 0.15, but the CrossOver appears to have deeper blacks because its bezel is not as dark.
Nah, i have them side by side on the same brightness setting, and contrast ratio is just much better on ST2220T (also tried with the S2340L on very low brightness with the same washed out picture)
If you have a Nvidia GPU you have to enable Ycbcr444 when using HDMI other wise the blacks will be terrible:
http://i1093.photobucket.com/albums/i432/240hzTeslaStorm/Asus VG23AH Review/CorrectHDMISettings.png
As I've said before, you should never do this. You're limiting your black range to 16-235 instead of the full 0-255. You can achieve the same affect by changing the HDMI black level setting on the monitor itself.
If you want to get proper 0-255 black levels over HDMI on an Nvidia GPU, just run the below utility.
http://blog.metaclassofnil.com/?p=83
Drags, I'm going to order that model soon as well. Any opinions/photos from you would be much appreciated.
Also, what about HDMI on an AMD gpus ? Will I have to change something as well ?
Could you have a look over here: http://www.lagom.nl/lcd-test/black.php and tell me if there is any black crush?
I think all VA based panels suffer from black crush. But yeah, let us know Drags how bad it is with this particular model.
Ive just tried this on my S2440L I've just picked up. By default using the RGB setting the black depth is awful, at around 0.42 cd/m2 (at default settings). When switching to YCbCr444 the picture immediately looks better and black depth is now 0.06 cd/m2 as it should be. If i revert back to RGB but use that utility to switch to full range then the black depth is again 0.06 cd/m2.
so the utility works fine, but are you sure the YCbCr444 is actually limiting the output range to 16-235? It seems more like the default RGB mode is limited to that range when using HDMI, and the YCbCr444 setting seems to extend that range properly, at least so you have the proper black range at the lower end?
Using YcbCr444 is fine (no negative effects) and is required on a few displays I've owned when using HDMI.
Any idea how the S2440L is so cheap on Amazon or when it'll probably arrive in stock?
http://www.amazon.com/Dell-C9VNT-24-Inch-LED-lit-Monitor/dp/B009H0XQRI/ref=sr_1_1?ie=UTF8&qid=1349832902&sr=8-1&keywords=S2440L
Who knows but after the review I decide to cancel my Amazon order for it But if your order it they suppose to send you an email with an eta(I never got mines though)
If using RGB, your monitor will default to 0-255 full range. Some monitors will have an option to drop down to limited range (16-235) which will make blacks look proper on an NV card. By using YcbCr, your'e telling the monitor, "Hey, I only do 16-235." So, this setting gets locked out, which is why it looks correct.
By running the utility on RGB, you get full range (0-255). It's a suble but appreciative improvement in some cases.
It's not required if you prefer full-range. In fact, it's a hindrance in this case. Leave yourself at RGB, use the utility, and you're set. By using YcbCr, you're using limited range.
Hey NCX,
Any word on altering or disabling overdrive from the service menu?
Newegg has the S2240M for like $30 less than Dell's own site. Can't figure how they can undercut Dell on one of their own monitors. lol. (Edit: I see other Dell monitors cheaper on newegg too). Does Dell offer better warranty/guarantee when ordering direct from them?
Ive been looking for a glossy display 24" / 27" for long time.
I mostly use photoshop for web design. I hate AG coating displays.
How is the glossy panel on this one compare to for example a Sammy 120HZ
what i don't understand though is that using the YcbCr option clearly doesn't seem to limit the range to 16 - 235, as if it did the black level (0) would be different to when using full 0 - 255 range wouldn't it? I've measured the black level at the same value when using YcbCr mode as when using RGB with the tweak to make it full range. the only time range seems to be limited, and therefore black measurement is rubbish, is when using RGB mode without the tweak
Why? Seems like the only thing wrong with it was overdrive, which may possibly be turned off from the service menu. Since the display has such low input lag, I'm sure there is enough leeway to compensate for the added input lag of turning overdrive off.
I was going to use it for gaming and blu ray. But since I'll be watching movies from the bed(not dead on), the color shift worries me. So I'm thinking about getting the S2340L, but once again there are mix reviews from other members. So until I can come to a decision, I'll just keep praying my 17 inch CRT last forever(Philips 107E5).
