Hi, I have a few questions about timings on a system i have. It's an A7N8X D 2.0 , w/ a AXP3200 Barton 400 fsb & Corsair XMSPC3200 2X 512. Everything is stock, didnt want to OC this PC as several others use it . Cpu & Memory are in sink @ 400 ( obviously) , my question concerns the timings. This all went together great and runs very stable, no errors in any memory tests, i would just like to know the best/correct timings to go with performance wise. Should i run it at 2-3-3-6 as the memory is rated to run, ( Corsairs site has updated that & for AMD systems it should be 2.5-3-3-6)
When my board detected the ram it set it to 2.5-3-3-8. I've built 3 systems now but memory timings im just learning about. So which is better ? 6? 8? Should i bring the CAS Latency down to 2 from 2.5?
Another question, in CPUZ, it shows the fsb slightly below 400 , like 398 or so, is this the norm? It's set to 200/400 in the bios, but cpuz likes to show it a little lower for some reason...
Sorry to be long winded, just trying to get the most out of this new memory and set it up right...Thanks for any replies!
