[H]ard|Forum
Go Back   [H]ard|Forum > [H]ard|Ware > Cases & Case Modding
Reply
Thread Tools Search this Thread
  #1
Old 02-24-2004, 08:34 PM
Sidgoop n00bie, 7.3 Years
Sidgoop is offline
Fiero Chair Mod (dail-up beware)
It wasn't my intention to hijack 8Complex's thread, so I decided to move it here. I got fed up with the normal computer chairs, and was looking for a good use for my secondary soundcard outputs. I had a friend who had a Fiero back in High School, and was amazed that the seats actually had the speakers built into them. So the quest was on to get me some. I tried the local junkyards, but every Fiero "speaker seat" was either missing the speakers, or water-logged beyond belief. That led me to ebay, where I scored a working speaker seat for $20. I needed a little amplification, so I went to BigLots and got a cheapo flatpanel speaker / subwoofer combo for $19. I just cut the speaker wires going to the flat panels and spliced them into the factory speaker jack. I then mounted the sub underneath the seat to give it the vibration effect. Here some close-up shots as requested:
This is the headrest with the cut out speaker grille
This is how I mounted the original armrests. They originally bolted into the frame, but were too low when I put the seat in, so I got some 4" bolts to raise them, and 3" pipe lengths for support. Not the prettiest, but it does the job just fine.
Here is the subwoofer mounted underneath the chair. The grille was made from an old 120 mm fan guard I had from an earlier project gone wrong. I secured all the wires in half-inch split loom, because poor wire management makes baby Jesus cry.
This is the business end of the chair. The most laborious thing about this project was cutting that piece of plywood that adapts the Fiero seat to the original chair mount. It's reinforced by some heavy duty steel straps.
And finally, the finished product, as seen in the other thread:
  #2
Old 02-24-2004, 08:56 PM
dunks Limp Gawd, 7.8 Years
dunks is offline
awesome
how does it feel and sound?
  #3
Old 02-24-2004, 09:15 PM
kill_emma Limp Gawd, 6.4 Years
kill_emma is offline
wow... just wow...
  #4
Old 02-24-2004, 10:03 PM
Tt Ownage Gawd, 6.1 Years
Tt Ownage is offline
must resist.. modding chair.........last thing i have left that still standing.......
nice job
getting some good vibrations off the chair?
lol
  #5
Old 02-24-2004, 10:07 PM
Drunkin_Master [H]Lite, 6.3 Years
Drunkin_Master is offline
DAMN that is awsome!!
How long did it take you?
You think you could make a chair for me?
  #6
Old 02-24-2004, 10:21 PM
Sidgoop is offline
The best thing about the chair is that it is extremely comfortalbe. It has great lumbar support, and it reclines. Well, to a degree before it becomes unbalanced. The speakers are stock Delco, so we're not talking Bose, but better than most run of the mill computer speakers. I looked into swapping them out with better ones, but I would have to strip down, and then totally recover the enitre seat. The entire project took less than 3 hours to complete. Like I said, the hardest part was actually locating a working speaker seat. I'm not out of things to mod just yet. I found a dead TRS 80 model III at a thrift store that's got mini-itx written all over it.
  #7
Old 02-24-2004, 11:18 PM
theNoid [H]ardness Supreme, 6.1 Years
theNoid is offline
NOW that is one sick ass job/idea. I never would have thought to take a seat from a car and use it, shit I might go to my local yard and see if I can get like a 7 series seat and mod that bitch...
nice work... /me bows
__________________
[-Intel Core 2 Quad Q6600 G0 @ 3.0Ghz
[-Gigabyte EP43-UD3LR
[-Diamond ATi 5850 @ 775/1125
[-4GB (2x2GB) OCZ Reaper DDR2 800
[-BenQ V2400W 24" LCD @ 1920x1200
[-Windows 7 Ultimate x64
[-2 Microsoft Xbox 360's (Elite\Premium)][-Nintendo DS Lite][-Apple 3G iPhone][-Samsung LN32A450 32" LCD HDTV]
[-Canon EOS Rebel XSi][-Canon Vixia HF10]
  #8
Old 02-25-2004, 01:40 AM
DeFex 2[H]4U, 9.0 Years
DeFex is offline
Quote:
That is probably a good thing bose = a name that costs $700 on a $800 radio
__________________
i7 920 @ 3.15 | Asus P6t SE | OCZ Vertex60GB |12GBOCZPlatinum | WDblack500 | WDblack1TB | Quadro4600 |Win7
mixing + fx n synths E5200 + creamware scope + creamware scope + creamware pulsar2 2GB samsung 24" + Xp32 /
cubase: Xeon 3210 @ 3.0 + 4GB + EMU 1212m samsung 24" / E6600 music server 2GB Xp32 /
Portable Sound design + HTPC DG41MJ + E7300 + Creamware pulsar1 in 2u amplifier case. Xp32 / Dell mini9 + 32GB runcore ssd XP32/ CNC shuttle korporate kube + pentium5200 XP32
at Work-workstation Dell T7400 with dual X5450 and Dual quadro 4600 16 GB XP64.
  #9
Old 02-25-2004, 02:43 AM
Snow4832 Limp Gawd, 7.3 Years
Snow4832 is offline
all you need is a lil 10'' sub on the bottom to shake ya around
  #10
Old 02-25-2004, 03:35 AM
jeska Limp Gawd, 6.4 Years
jeska is offline
nice
  #11
Old 02-25-2004, 10:25 AM
Wanamingo [H]ard|Gawd, 9.2 Years
Wanamingo is offline
Quote:
Look again, he has a little sub. Maybe not 10", but he has the bass covered.
__________________
I need a new signature.
  #12
Old 02-25-2004, 10:50 AM
rkatapt [H]ardness Supreme, 7.1 Years
rkatapt is offline
So are you using the headrest speakers for another soundcard output or for your rear surrounds. nice job by the way......
  #13
Old 02-25-2004, 01:06 PM
Spidey329 Gawd, 6.2 Years
Spidey329 is offline
Nice!
For the those wanting to mod a chair. You can get a really comfortable Corbeau (racing seat, excellent support) knock-off in various colors (cloth, a vinyl or actual leather) from $149.99-$249.99 (depends model) at PepBoys. I haven't located them online though.
  #14
Old 02-25-2004, 11:05 PM
jpnelson83 Gawd, 7.8 Years
jpnelson83 is offline
Here pull that sub off and mount these guys to your chair and then you'll really be rocking.
  #15
Old 02-25-2004, 11:10 PM
BIGJEFF Limp Gawd, 7.7 Years
BIGJEFF is offline
wow tight work
  #16
Old 02-26-2004, 12:12 AM
violetcypher n00bie, 6.5 Years
violetcypher is offline
Idea
If that sub can't get the GF into gaming nothing will.
  #17
Old 02-26-2004, 08:22 PM
mustang_steve c[H]ewbacca, 6.5 Years
mustang_steve is offline
Hmm, can the spekers inside of those chairs be replaced?
If so, what size are they? I might have found a use for my old 3-1/2" infinity coaxials if they will fit
One thing that might be good if you ever go for more power. Buy some bass shakers (made by the now defunct aura, but they are still found online). All they do is add rumble to your seat, but are powered off of a normal amplifier output. I think you can get a set of two for like $40 or a "pro" model (stronger rumble) for about $30 each.
__________________
Cleverbot lulz:
Me: do you have any condoms, I don't want to catch a computer virus, I have no idea who've you've been pinging....
Cleverbot: If I lie I will never talk to you again.
  #18
Old 02-26-2004, 08:34 PM
Kaos [H]ard|Gawd, 6.3 Years
Kaos is offline
lol i used to have a gt fiero and i swapped out the 2.6 for the SB....i shoulda kept my seats.
__________________
Network Security: A good defense is the best offense
Try not to look down on anyone unless you plan on helping them up.
  #19
Old 02-27-2004, 04:17 AM
I found out the fiero seat speakers are 3-1/2", but they aren't exactly mounted either...tehy are encased in the foam of the headrest. So any replacement job is going to be a slight pain to do. Other issue is the max depth of 2", as there is a metal plate right there....this could limit choices of replacement speakers.
__________________
Cleverbot lulz:
  #20
Old 02-27-2004, 02:44 PM
topcat989 [H]ardness Supreme, 9.1 Years
topcat989 is offline
dude that is just wicked sick. awesome job
__________________
topcat989@(nospam)hotmail.com
Pay Pal VERIFIED & address CONFIRMED
(heatware FB)http://www.heatware.com/eval.php?id=3238
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Valid XHTML 1.0 Transitional
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2000 - 2009 KB Networks, Inc.
