I recently came home to a blank screen, motherboard was cycling "EA 01 68 02". I rebooted the computer and it started cycling "F3 F6 b8", and the computer just keeps rebooting. I've tried reseating the CPU. I tried running only one stick of RAM in Slot 1 (three different sticks that were in the system working before). I replaced the CMOS battery. I've left it unplugged overnight. I started it without the CPU and received an "FF" code. I'm not sure what else I can try. I've searched online and found many others who have had this issue, but have not found anyone who could pinpoint a resolution. I sent a ticket in to EVGA and received the following response:
"Those post codes are usually related to RAM, especially if you see the board boot looping with those codes. As you've tried sticks individually, there's two other possibilities. First, the board has developed a fault with the RAM slots, or two, the CPU has developed a fault with the RAM controller. Unfortunately, the only way to test these theories would be to test the components in another machine."
I don't have anywhere else to test this stuff. Anyone dealt with this, and what did you find to be the issue? Thanks.
