GoldenTiger
- Dec 2, 2004
Here's a review someone found I thought was worth posting as this kind of comparison is often cited but rarely has data to answer it so far:
http://www.reviewstudio.net/2028-asus-gtx-970-strix-oc-review-bring-the-maxwell-to-the-owl
It compares a 1228mhz GTX 780 Ti OC vs. 1300mhz GTX 780 OC vs. a 1530mhz GTX 970 OC, for the curious (boost clocks as stated in the text).
The 780 Ti in the review is stated to be running at 1228mhz boost in-game with 1975mhz memory (7900mhz qdr)
(http://www.reviewstudio.net/1179-as...iew-best-performance-dead-silent/overclocking) and you can find the same reference in the 780 OC review on their site.
BASE CLOCKS are listed by them in the graph. Boost clocks according to the review are as stated above . This is actually the best oc-to-oc comparison between a 780 ti at good clocks, 780 at good clocks, and GTX 970 at good clocks, that I have seen yet.
The gap in other reviews narrows a little at 4K, while remaining similar to 1080 when done at 2560x1440 resolution, keep in mind. (They have a 3dmark score in there too but list the combined, rather than GPU, score which makes it meaningless ). The GTX 970 oc'd stacks up very favorably to the GTX 780 Ti oc'd and consistently beats out the 780 oc'd.
