negachampa
- Nov 12, 2013
Ok, for those who have been following my other thread. I am now back form my work trip and have some results from my trifire and crossfire benchmarks.
All settings are max at 2560x1600.
For BF4 the resolution slider was also set at 150%, which means the game is rendering it at 1.5x the res of 2560x1600 then downsampleing. This have a big improvement on IQ but really stresses the cards.
290s were OC to 1075Mhz for all the tests.
Corssfire (2 290s ) Results:
BF4
Min = 41
Max = 72
Avg = 54.511
Metro Last Light
Min = 14
Max = 186
Avg = 46.02
Crysis 3
Min = 55
Max = 73
Avg = 62.165
Unigine Heavn 4.0
FPS = 57.7
Score = 1454
Trifire (3 290s ) Results:
BF4
Min = 49
Max = 99
Avg = 79.683
Metro Last Light
Min = 12
Max = 182
Avg = 46.08
Crysis 3
Min = 69
Max = 108
Avg = 89.267
Unigine Heaven 4.0
FPS = 85
Score = 2141
And there you have it. Not bad at all. Only odd ball was Metro , for some reason I get the same results. I guess trifire does not work with Metro. But for the reset, when trifire is working the scaling is very, very, impressive. and I am sure things will only improve as driver mature for the R9 series.
Also there is no sign at all of microstutter. Like I said before I am new to AMD so I do not know what the microstutter was like before but from a long time SLI Nvidia user it is just as smooth as SLI.
Over all I am very impressed with these R9 cards, other then the heat and noise. I have to set max fan profile using Afterburner to 80% to maintain 1075mhz on all cards with no throttling. They will all 3 stabilize at 90 C under full loads.
Hopefully this helps other make the choice or not to go trifire. Considering that the cost is less then 2 780tis I still think it was worth it.
Cheers
BF4
Min = 41
Max = 72
Avg = 54.511
Metro Last Light
Min = 14
Max = 186
Avg = 46.02
Crysis 3
Min = 55
Max = 73
Avg = 62.165
Unigine Heavn 4.0
FPS = 57.7
Score = 1454
BF4
Min = 49
Max = 99
Avg = 79.683
Metro Last Light
Min = 12
Max = 182
Avg = 46.08
Crysis 3
Min = 69
Max = 108
Avg = 89.267
Unigine Heaven 4.0
FPS = 85
Score = 2141
Cheers
