anyone know why these aint recommended for installing a OS on ?
Win7 Pro is like 15 gb.
Pretty much what was said above.
The better way to go with this drive would be to use it as an SSD cache.
for the Z68 SSD caching, you need at least 18.7GB of space
other software/hardware solutions, dunno?
Win7 is only around 6gb if you disable system restore + hibernation, and make the page file smaller. So, this would work for a really small box .
That hasn't been my experience...even with those off my Windows directory is still like 15-20 GB and I've only been on this current install for a month or two. Are you talking Win7 Pro? What else is taking up that space?
EDIT: I guess I had system restore off but hibernate "capability" was still on. Disabled it in command prompt and got back like 9 GB. Windows dir itself did not change, though, and is still 20 GB.
EDIT: Got it from 10 GB down to 6.7 GB. Not bad, especially when you're using an SSD with limited space. Here's the information if anyone else wants to try it:
http://www.iishacks.com/2011/06/23/reduce-windows-7-winsxs-folder-size/
I realize this is somewhat off-topic but for anyone buying this it could be very useful.
Thanks for that info as well, I was about to buy it for that purpose.
Edit: Where did you find that information out? The link below says that "The SSD and hard drive can be any capacity, but its worth bearing in mind that SRT can only use up to 64 GB of space on the SSD, so it isnt worth buying a larger one."
http://www.hardwaresecrets.com/article/Intel-Smart-Response-Technology-Explained/1292/1
Tempting, but I wonder whether this drive supports GC or TRIM
Deal is deal. Seller is now offering 16gb SSD's for $170 under a new posting.
http://www.ebay.com/itm/10-Samsung-...=WDVW&rd=1&ih=014&category=38119&cmd=ViewItem
Seller's remorse I guess.
Note: This is a Multi-Level Cell SSD and therefore is not recommended for OS installation
These could be really nice for someone with a Z68 board looking to try out Intel's Smart Response Technology without spending a lot of money.
It was already pointed out a few posts above that you must have at least a 20GB SSD for SRT. So, no dice. It's a shame, as I'd consider purchasing one for that.
Sorry, I saw the quantity as quantity of single drives not a group.That's ten of them in that listing.
He has a seperate listing for single drives still at the OP's price.
This would actually be a great purchase if you plan on getting a Rasberry Pi.. Perfect for a little Linux distro
I'm not sure if that command they recommend is any different than running the SP1 cleanup tool that is under Disk Cleanup. I have an integrated SP1 installation at home so I'm going to test my theory, which is that the command will not work for me since there are no SP1 files to clean up.Page file is disabled. I did some digging and 10 GB of usage is in a folder called "winsxs", which is apparently service pack and update install/uninstall crap. There's supposed to be a cleanup tool built into Win7 that I will try and report back.
I almost wonder if your trolling. Windows 7 Embedded is completely different than Windows 7 desktop edition.strange i got win7 down to 1.3GB using Windows Embedded Standard 7
http://www.microsoft.com/windowsembedded/en-us/evaluate/windows-embedded-standard-7.aspx
