Matte:
Planar SA2311W
Alienware AW2310
Glossy:
Samsung S23A950D
Asus VG236HE
ok, so so far, why is it that nobody thinks s23a950d is that good? i was under the impression that since it was recently released, it uses newer technology..
My VG236HE arrived. A few things. Color is miserable out of the box, but is much improved after calibration. However, it still doesn't touch the color of my old gateway e-IPS display. Also, the default brightness will probably destroy your retinas, so you might want to dial that down quite a bit.
The display is indeed very reflective, although I don't noticed the splotchiness that I've seen on other glossy displays. The glossiness appears very smooth and uniform if that makes any sense. I will say, it hasn't changed my mind about glossy displays, and I will probably not be using the VG236HE as my primary display (will probably purchase a Dell 2412m).Contrast is good for an lcd. Also, there is some backlight bleeding at the top and bottom edges of the screen, although it's only really noticeable when the screen is black, and even then it's not bad.
The 120 Hz is indeed awesome. I just played a little Battlefield Bad Company 2 with maxed out settings with my 570 gtx putting out around 80 fps. It was extremely smooth. No need to turn on vsync. Oddly, I did see tearing while playing crysis (fps around 40). I'm not sure why, but I'm guessing it has something to do with the game settings. I did enjoy the glossiness for games.
Unfortunately, my display has ONE STUCK PIXEL. This is a major bummer in a 2010 monitor. I'll try unsticking it tonight.
Where do you get that it's 1 year warranty? Appears to have 3 years here.
