I thought it would be interesting to share how a LGA 775 board (Nvidia one at that!) performed with couple of GTX 460's.
The benchmarks were ran with my second rig.
Here is my setup:
Mobo: EVGA 780i FTW
CPU: Q9650 - OC'd to 4.0 Ghz
Cooler: TRUE 120
GPU: GTX 460 SLI - OC'd to 800/1600/2102
RAM: 4 x 2GB DDR2 800 (8 GB total)
Display: BenQ 241VW 1920x1200 res
Unigine Heaven results:
Here are some results from game benchmarking programs. All games were run at 1920x1200 resolution except the last game, FF XIV.
Crysis Warhead via Frambuffer Benchmarking Tool:
Min: 24.47 - Max 54.66 - Avg 43.61
Game was run at Enthusiast setting with AA @ 16x as you can see from the pic. The game rarely dipped below 30 FPS.
Alien vs Predator Benchmark Program:
Avg FPS - 60.5
The program does not provide any min or max FPS data but game rarely dipped below 45 FPS. All settings were set to max with all graphical features enabled. AA was at 2x.
Lost Planet 2 Benchmark Program:
The benchmark was run using the "B" option, which is the boss battle. All graphical settings were set to max with CSAA @ 16x.
S.T.A.L.K.E.R.: Call of Pripyat Benchmark Program:
Again, all settings were set to max with MSAA @ 4x.
Finally, FF XIV Benchmark Program:
Avg FPS was around 83 monitored via Fraps. The min FPS rarely went below 55.
The benchmark was run at High setting (1920x1080 res).
And the LGA 775 keeps on kicking...
Here is my setup:
Mobo: EVGA 780i FTW
Cooler: TRUE 120
Avg FPS - 60.5
