Edit: Heres some pictures of my new case(s) taking shape.
Im plan on fitting at least 2 full ATX boards in this box
Its 28" high, 24" inside diameter 24" deep tray
got the 1st slide out tray done, doing the 2nd one in a minute
any ideas on things I should add as I go along?
http://img51.imageshack.us/i/photo1np.jpg/
http://img411.imageshack.us/i/photo2ld.jpg/
To Do:
- Finish squaring up the outside so I can put a good wood finish around it.
- Drill a good sized hole on each tray for wiring
- Think about some sort of interior lighting
- See if I can mount 2 PC's per tray
- Think of cooling options once its inclosed.
- Snazzy looking items like a temp monitor...
To Do:
