anttipantti
- Jul 21, 2009
Hello guys!
I'm looking into buying a broken 305T+ and would know if other people have had the same problem and know how to fix it. I know and have been taught the basics of electronics and such.
This is what I know about the problem:
There is no problem when the monitor is powered up without feeding it signal through the DVI port.
After you start feeding it signal through the DVI, the monitor starts flickering and outputting lines of different colors, sometimes more sometimes less (afaik it works perfectly sometimes but the flickering has gotten more frequent and worse over time)
It has been tested with multiple pcs and gfx cards.
SO the problem is not the source nor the panel itself so it has got to be the DVI connector, right? Anyone here know a way to fix the monitor/connector. I take it would be too hard to go as far as changing the connector because there are so many pins/leads?
