rowdypixel
- May 1, 2008
My birthday is the last day of January, and the computer in my sig is really holding me back. It's time for me to upgrade as a birthday present to myself. I've been creating this list and keeping it updated for the few months, so I'm confident in most of the parts I've chosen, but I would still like to get some feedback.
I'll be using it for everything. Web browsing, light gaming, programming, office work, etc.
$600 before taxes and shipping.
3) Where do you live?
USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I'll be getting everything but the monitor, mouse, and speakers.
I'll be reusing the aforementioned parts.
6) Will you be overclocking?
Yes.
7) What size monitor do you have or plan to have?
19" widescreen running at 1440x900
I'd like to build it by February
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I don't need anything special here. Just a basic mATX board with at least one PCI-e and PCI slot which can overclock the E5200 to around 3.5-4GHz.
Now for the build(s):
Case: Coolermaster Elite RC-340 - $30.00
Motherboard: GIGABYTE GA-EG31M-S2 LGA 775 Intel G31 mATX - $55.00
Power supply: SILVERSTONE ST400 400W Power Supply - $50.00
Processer: Intel Pentium E5200 2.5GHz Dual Core Processor - $85.00
Hard Drive: Western Digital WD3200AAJS 320GB SATA - $50
DVD Drive: Samsung WriteMaster SH-S203F - $25.00
Memory: 2x Kingston 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 - $66.00
Cooling: Xigmatek HDT-S1283 w/ mounting bracket
- 2x Yate Loon 120mm Low Speed Fans - $10.00
- Yate Loon 80mm Low Speed Fan - $2.50
Video Card: Asus Radeon HD4830 512MB - $120.00
OS: Windows Vista Ultimate (Product Red) Upgrade 64-bit - $65.00
Extras: Rosewill RTK-002 - $3.50
- Vibration Dampening Hard Drive Screws - $1.50
Total: ~$610 before taxes and shipping
My biggest concern here is the mobo. From what I've read, the GA-EG31M-S2 isn't a very good overclocker. I've heard that the Asus P5E-VM HDMI is good, but it's also twice as expensive and out of my budget.
Also, since the E5400 is supposed to come out around January 18th, I plan to wait until then to start ordering parts. I'll most likely substitute the E5400 for the E5200, but if I need money for a different component, I'll save a few bucks then and get a cheaper E5200.
USA
Yes.
