so basically i just built this pretty good computer with decent specs. now i just want to achieve maximum performance with my new rig. i am not really concerned with overclocking, as long as the standard settings are fast enough. i was hoping if anyone had a similar build they can give me some advice on how to set the bios and what little mods i can do to make my computer run at its best.
at the moment i have everything on system default and was wondering if anyone can tell me how to properly set up my bios accordingly with my components.i.e voltages,system clocks, cpu configuration and so on.
also any suggestions to overclock a little bit to increase performance without risk of damaging components is great too.
detailed list of system specs
thermaltake kandalf va9000bws case
650 watt antec true power trio power supply
xfx 790i ultra sli motherboard with p06 bios
qx9650 core 2 extreme processor @ 3.0ghz
true 120 heatsink with 120 mm fan
Corsair TWIN3X 1333MHz DDR3, 2048MB, DHX ,Kit w/two 1GB XMS3 modules, CL9-9-9-27 1 GB (TWIN3X2048-1333C9DHX G) ( 3 1gb sticks )
zotac 8800 gts ( g92 ) video card
x fi platinum sound card
160 gb raptor hard drive
2 terabyte hard drives for storage
Vista OS
Current temps C"
system 90
CPU 42
aux 39
Vista OS
Current temps C"
system 90
CPU 42
aux 39
