I made this thread because I've seen quite a bit of them popping up individually. Let's use this to discuss HP's new line of widescreen LCD displays, the wxx07 series.
I'll start off saying that when I got this monitor home, I was amazed at the clarity of everything I threw at it, and that gaming on it is great.
I did, however, receive one with a stuck pixel and will be exchanging it soon for the same one.
Overall a very SATISFIED user!
Update: After having exchanged it, I received one with absolutely NO defects.
No dead/stuck pixels, and even the backlight was better than the previous one.
No noticeable bleeding even while using a solid black background! This, of course, may be luck of the draw.
Contents of package:
Some key points I've noticed about the monitor:
**Pictures have been removed due to host being down.
- Monitor (or at least one would hope)
- Driver disk
- USB cable
- Power Cable
- VGA cable
- does not come with a DVI cable
- Good cable management
- Strong, stable arm. Supports 90degree turning
- Good menu
- Option to turn off the power button's LED
- Streamlined position of the power button) on top, out of sight
- Great colors and brightness
- Vertical angle fading not as apparent as on the Samsung 226bw; very exceptional considering the size of this TN panel
- Very minimal and hard-to-notice backlight bleeding
- No color bleeding
- No ghosting in games
- Two USB inputs on the left side (out of view)
