[H]ard|Forum
Go Back   [H]ard|Forum > [H]ard|Ware > Video Cards
Reply
Thread Tools Search this Thread
  #361
Old 06-12-2009, 08:37 AM
CoachB [H]Lite, 3.3 Years
CoachB is offline
I tried this with an old Socket 754 motherboard. After about 5 minutes at 380 degrees, the capacitors started exploding like popcorn. One actually blew itself off the board. Needless to say, that board is now "fixed".
__________________
AsRock Sata II w Opty 144@ 2.7 Ghz
Epox 9GF6100-M w Opty 148@2.9 Ghz
  #362
Old 06-12-2009, 09:23 AM
jonneymendoza 2[H]4U, 5.2 Years
jonneymendoza is offline
can i put my 360 in the oven if it breaks? :P
  #363
Old 06-12-2009, 05:11 PM
Chibo n00bie, 6.4 Years
Chibo is offline
Quote:
Yeah, just videotape the result.
  #364
Old 06-12-2009, 05:20 PM
g0dM@n 2[H]4U, 4.0 Years
g0dM@n is offline
Quote:
You're kidding... it really works now??
__________________
Gigabyte X48T-DQ6 *Water* | E8500 E0 w/ D-Tek Fuzion custom mounted | 4GB OCZ 1600| 4870 1GB w/ MCW60-4870 | 3x74GB 16m Raptor Raid0 + File-Svr 2.25TB | SB X-Fi Fatal1ty | TT 650W Modular | Westy 37" 1080p + Dell 2405FPW | DDC pump with petra top, Thermochill HE 120.3 w/ 3x120x38mm Deltas 152cfm on controller |
Xbox 360 on 47" 1080p | Gamertag: g0dMAn114
700+ flawless heat:
http://www.heatware.com/eval.php?id=35578
  #365
Old 06-12-2009, 05:39 PM
kioras Gawd, 1.4 Years
kioras is online now
Quote:
Fixed...
Just like you bring a pet to get fixed at the vet probably.
  #366
Old 06-12-2009, 05:45 PM
LOCO LAPTOP - I Bring a Full Size PC when I Vacation, 3.6 Years
LOCO LAPTOP is offline
Looks like gonna try this with a gigabyte GA-EX-58-UD4P.
Anything else that needs to be done other then remove the heatsink/tim?
EDIT: does anyone think this would work with a dead cpu? (never oced/overvoltage)
__________________
Gaming Rig: Core i7 950 4.2Ghz, Gigabyte GA-EX58-UD4P, 12GB DDR3 PC12800, x4 640GB Western Digitals, x2 BFG GTX260 OCX, Ultra X3 1600W psu, HP 2408W
Server: Dual Xeon E5520 2.26Ghz, SuperMicro MBD-X8DAH+-O, 12GB DDR3 PC10600, x2 1.5TB Hard Drive, XFX 8600GT,Ultra x3 850W (The work in progress server)
Gaming Laptop Sager9262: Q9650 3GHz, 4GB 800MHz Memory, 1.5TB RAID 0 (3 x 500GB 7200RPM), SLI Dual nVIDIA Geforce 8800M GTX, 17" HD WSXGA+ 1680x1050
  #367
Old 06-12-2009, 06:13 PM
holy shit.
I fixed my AMD BE-2350 by using a Micro-Jet Torch on the top of the cpu for 5 mins. then I let it cool down for 5 mins then tried it. AND IT WORKS
__________________
  #368
Haste266 [H]ardness Supreme, 4.2 Years
Haste266 is offline
Quote:
Originally Posted by LOCO LAPTOP View Post
holy shit.
damn, nice.
__________________
E5200@3.6ghz on a Gigabyte GA-E7AUM-DS2H w/9400 IGP / EVGA 285 GTX
OCZ Reaper HPC 2x2GB DDR2-1066 / 1x 150gb Raptor / 2x 750gb Spinpoint F1
1x Maxtor 320gb / 1x LG GBW-H20L
Thermaltake Armor / Antec EA650 / Creative X-Fi Xtrememusic
MCP655, Apogee GT, MCR-220 / Vista Ultimate x64
Sony GDM-FW900 24" Widescreen CRT
Heatware: haste266 | E-Bay: haste266
  #369
Old 06-12-2009, 06:15 PM
Quote:
Originally Posted by Haste266 View Post
damn, nice.
Only if I did a video showing I wasn't kidding.
Time to find an other CPU to test this on.
__________________
  #370
Old 06-12-2009, 06:38 PM
g0dM@n is offline
holy shit.
Dude, you're joking, right?
What was wrong w/the cpu?
__________________
700+ flawless heat:
  #371
Old 06-12-2009, 07:03 PM
No post on both of my motherboards but worked with x2 6400+ and a x4 9850. No idea what the hell happend to it. but all it matters is that it works and from the looks of it, it's stable.
I have no clue how this trick fixed it...
__________________
  #372
Old 06-12-2009, 08:33 PM
SL01947 n00bie, 6 Months
SL01947 is offline
To the OP, thank you so much!!!!
I got given a 8800GTX because it had bad graphics corruption during post, odd yellow lines when loading windows and windows would blue screen whenever trying to load the NVidia drivers, so it was pretty much toast.
I found your article today and decided to give it a try; I had already cleaned the heatsink out (it was pretty chocked full of dust) and reseated the heatsink with artic silver which made no difference at all.
I followed your instructions and put it on a tray, upside down, suspended by small bits of crunched up foil and put it in the oven between gas mark 5 and 6 (about 400f) for 9 minutes, after which time I shut off the gas and opened the door, but didn't move it for 5 minutes or so in case it unseated anything.
The board warped a little on one corner (or it was already and I didn't notice before) but otherwise, no bad signs. I re-assembled once cool (wrenched the head off one of the small screws around the GPU retightening it, but don't think that will be a problem) and put back in the machine, not expecting much, but to my amazement, it posted perfectly and booted straight into windows with no corruption at all using the latest NVidia driver!
It has now been running for about 5 hours in which time I have solidly been running 3Dmark06 on it trying to get it to go wrong, but it is working perfectly! It is benchmarking 8501 in 3Dmark06 which I don't know if is where it should be, but the graphics while testing are amazingly smooth The rest of the PC only has 1.5GB RAM, a 2.0ghz dual core pentium and an older conroe 1333 motherboard (some bits I had laying around I threw together to see if I could get the card working).
The other thing I noticed is while it was faulty, it used to get VERY hot, to the point it burned you touching the heatsink; I don't know how hot because it wouldn't load the NVidia drivers to open NVtune to get a reading, but now it is idling at 45 degrees c and only goes up to 56 degrees c running 3Dmark and is only warm to the touch.
So again, thank you VERY MUCH!!! I now have a pretty good gaming card which cost me nothing!
  #373
Old 06-12-2009, 08:36 PM
Haste266 is offline
awesome. thanks for the post!
did i mention already that i take donations?
__________________
  #374
Old 06-13-2009, 10:14 AM
inotocracy [H]ardness Supreme, 5.3 Years
inotocracy is offline
Actually yeah, you can. There is a tutorial somewhere on how to disassemble it get it prepped but they using a reflow gun (which is just isolated heat). Same concept but just a slightly different approach.
__________________
Intel C2D E8400 @3.75ghz (9x415)
4GB DDR2 800
Gigabyte P35-DS3L
Radeon 5870 1GB
SB Audigy XGamer
WD Raptor 150GB
  #375
Old 06-13-2009, 12:47 PM
Gulkor Limp Gawd, 2.8 Years
Gulkor is offline
i tried my gateway 7322gz motherboard one of the tiny chips came off / i put it in the oven at 400F for 15 minutes and it reconnected the pieace that fall off. it worked and was on there but the laptop did not boot. i think the mobo is just bad and cant be fixed so i will be on ebay for other board 1 that is non working and try it as a fun project
  #376
Old 06-13-2009, 03:01 PM
akashi_tm n00bie, 6 Months
akashi_tm is offline
I've done it too for my half-dead video card that kept giving a No signal input after a few seconds of starting the machine. It worked wonders and now I can stick with it until I upgrade to a new system that I wanted to do anyway in a few months... BUT NOT NOW.
Here's a *short* video I made if anyone wants to see the process: http://www.youtube.com/watch?v=R7jUqoKVY-k
  #377
Old 06-13-2009, 03:08 PM
Haste266 is offline
nice vid. short and easy to follow.
i like ur pink oven mitt!
__________________
  #378
Old 06-13-2009, 03:16 PM
That's my mom's. It's handy. And although I'm a chick I don't usually go with pink. ^_^;; Heh heh
  #379
Old 06-13-2009, 04:37 PM
CruisD64 Gawd, 2.7 Years
CruisD64 is offline
You made that beat? Right on!
__________________
q9550 @ 4.2 | 8gb | P45 | 4870x2 | Corsair 850 | 40" 1080p
q9550 @ 4.0 | 4gb | P45 | 4890 | Corsair 750 | 37" 1080p
e8500 @ 4.0 | 4gb | x38 | 8400GS | OCZ 850 | 24" 1080p
When in doubt, mumble
  #380
Old 06-13-2009, 04:50 PM
Quote:
Oh yea.. many years ago. Didn't want to get in any copyright thing. Are we being off topic? >_>
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Valid XHTML 1.0 Transitional
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 2000 - 2009 KB Networks, Inc.
