JHefile
Necrophilia Makes Me [H]ard
- Jun 22, 2003
why is the m4 better when the pyro has much better read/write MB's
you want a drive with sync nand. the m4 has sync. if you really want a patriot drive, you would purchase the patriot wildfire, which has sync nand and will perform like the left side.
http://www.newegg.com/Product/Produ...yMark=False&IsFeedbackTab=true#scrollFullInfo
I'm going to get this one. gjs278 suggested it. It's cheap too.
You don't have to use TRIM, but why wouldn't you want to? Also, if you didn't already buy the Sandisk, the Plextor M3 is on sale for $10 more
http://www.newegg.com/Product/Product.aspx?Item=N82E16820249014
http://www.amazon.com/Plextor-PX-12...8EJ2/ref=sr_1_1?ie=UTF8&qid=1333998077&sr=8-1
if price did not matter, what SSD would you guys recommend? That ^ SanDisk looks pretty good... Is there any better???
if you are really crazy, you hire someone to create you a bootable pci-e card. on it, you place 64gb of ram and a 64gb ssd. on startup, you have the ssd contents copy into ram, and then you purely use the ram for your reads. you do your writes to the ram and the ssd, but all of your reads happen off of the ram.
