Yoshmaista
- Jan 5, 2004
Maybe you guys can help me here, as I was having a problem.
I'm trying to set up a NetGear Wireless G router just as an access point at my college. The techies said that I could as long as I put a WEP key on it and make it private, just so you don't get on me for doing something that is frowned upon.
I first plug my one computer into the router LAN ports, and I configure it to use an IP address like 192.168.1.99 so I'm able to connect to it once I connect it to the school network. So I change it to 192.168.1.99, turn off DHCP (so it doesn't assign me a LAN IP). So, afterwards, I take the otherLAN cable, and string it from the jack in the wall to one of the LAN ports in the router (I know it's not supposed to go into the WAN port).
The problem lies within the wireless. It seems that right when I plug in the school connection to the router, the wireless is almost "disabled", as if it just doesn't broadcast it. Also, I'm not able to login to the router at 192.168.1.99, even after I changed it. One more thing is that if I have my laptop hardwired into the router, and the school connection is also there, I can browse the net and such just fine. So it seems something is up with the wireless, or something is happening to the router IP address so I can't get back in there to enable/disable settings and such. Do I need to change the router IP address to something in the schools IP range? (For the record, I think it's 172.16.32.xx. 172.16.32.32 is their gateway)
Any help is appreciated.
the model number of the NetGear is the WGR614, and I have followed all the guides posted by Netgear to make this router an access point. I just get held up at the "change the router IP to 192.168.1.99. You will then lose connection because the IP has changed". I then enter 192.168.1.99, and I can't access it anymore.
If you need any clarification if this is confusing, just ask!
Thanks a bunch guys
Thanks a bunch guys
